Joystick (Xinput) icon Joystick (Xinput) — XInput joystick skill for ARC: maps Xbox controllers to movement, servos, triggers, vibration, variables; supports analog inputs and scripts. Try it →
Yes you can:) I have a robot named Cy and I do the same thing.
Ronbklyn, edit the speech recognition and change the text that is received. This is a good tutorial: https://synthiam.com/Community/Tutorials/110
I also recommend checking the manual. You can check the manual and get help from a control by pressing ? (question mark) next to the X on any control.
Thanks I will try explore that tonight
