Read Digital icon Read Digital — Read TTL digital input from an ARC I/O port; real-time red/green status for low (0V) or high (+3.3/5V), selectable board/port and read interval. Try it →
Singapore
I Don't Httpget What's Wrong
I was excited tonight as I was able to connect to my EZB via client mode for the first time. (Previously my anti-virus software was preventing the scan from succeeding) So I started playing around with various internet controls and script commands in EZ_Builder.
Pandorabot works fine, and I am able to communicate with my JD on my network OK, and also able to browse websites via my standard browser OK.
Next I attempted to use HTTPGet and here I am encountering a blank wall, despite the apparent simplicity of this command, it's not working for me. I opened the sample project (HTTPGet.ezb) and executed the script which is as follows:
print("Getting Google's homepage...")
$ret = HTTPGet("https://www.google.com";)
print($ret)
and the debug output shows the following:-
Start
1: print("Getting Google's homepage...")
3: $ret = HTTPGet("https://www.google.com";)
5: print($ret)
> Error on line 5: Variable not defined: $1
Done (00:00:00.2006382)
Within the script variables tab, I see the following:
and within the variables watcher panel I see $ret is a type string with a length of 50,869 characters:
I have ensured windows firewall is off and I have no other antivirus/antispyware/ant-anything running on the system. I receive the same symptoms no matter what URL I try to get. I'm using the latest version of ARC on Windows 10.
Can anyone shed some light on what may be the problem here?
Thanks in advance.
@DJ Thank you for your offer to help convert my scrubber program into a plug-in. What would you need to know? I'm not sure what is meant by "help" in this situation.
