Joystick (Xinput) icon Joystick (Xinput) — XInput joystick skill for ARC: maps Xbox controllers to movement, servos, triggers, vibration, variables; supports analog inputs and scripts. Try it →
How To Wire Up A Robot
here are some ideas to have less problems with you robot one is try to keep signal wires seperate from power wires.if you cant then twist the power wires to blocks the EDDY currents
another is use SPG (single point ground) witch is all grounds go to a center point or screw
if you looking at why your board sometime resets or other problems,(unstable readings) this might be the cause of it been wiring boards for over 25 years,from slot an pinball machines,very precision equipment ,plus robots
i guess you are making one eye stewart minion
Something like that. I had to make some modifications but here was the first draft. Only pic I have here with me.
Lol back to wiring. The best way to organize wiring.is.buy a bag of 1000 zipties , run signal wires together but do not twist them. You can buy multi conductor stranded wire that's for.servos/sensors by the roll cheap. Run your wires keeping.them tight together , ziptie every 4 inches ( but.every 8 inches.is fine.temporary until you have the placement perfect) power wires should now be within a inch of a signal wire AMD you should stick the.end of your power wires in a drill , tightened to.chuck down and used the drill.to twist the power and ground wires. Twisting power and ground creates capacitance that muffles electronic.interference. for power and ground use barrier strips /distro boxes. They insure great connections and easier to trouble shoot.problems.
Yes back to wiring. This is more how to organize. I thought this was going to be about actually how to wire something. Ex.
I have 2.5 Amp Motor Controller, EZ-Board and MP3 trigger. I would like to figure out a way to wire them all up to say a 12v battery.
Sorry I am semi technical, can follow directions but I am new to electronics in general.
#15
zip ties is all i use at work and my robots,and speaking of using a drill to twist wires i made a programable wire twister at work grounds should always to tied at one point like a screw terminal ,thats what called SPG single point gound also instead of using zip ties,i use spiral wrap tubing,makes it nice and neat
@jstarne twisting wires not always great idea best always is to seperate the the power wires
@sfoy since you have only a 2.5 amp controller ,you can twist the power wires together and same with MP3 trigger what 2.5 amp motor controller are you using,second you will need a dc-dc step down circuit since i dont know if you can build a simple circuit here is one that will work ,12 volt in 7.5 volts out
dc-dc step down converter its about $3.55 from china screw terminals pretty easy to use 12 volt and then adjust for 7.5 output and 2 amp fuse inline with the battery ,i bought 30 of them ,great dc-dc converters super easy to use and adjust
#16
I purchased the 2.5 amp controller from EZ. I never even heard of a step down circuit. OK. Now I am technical enough where I can follow a schematic. (I took a make workshop and successfully built a tv b gone) hahahahaha.
Now do I need this step down thing because of the voltage of the battery? Would it be easier to use a lower voltage batt?
Sorry newbie
Thank you!
