Sphero Movement Panel icon Sphero Movement Panel — Control Sphero via Bluetooth in ARC. Detects two COM ports (one connects); requires deleting and re-pairing after disconnects or reboots. Try it →
Hitec 5995tg Digital Vs Power Hd 1501mg Analog
Hitec 5995Tg Digital Vs Power Hd 1501Mg Analog
Though the hitec is stinger and smoother simply because it is digital I noticed.some.issues.of consistency so I directly compared consistency between.servos
first i see it very jumpy on HD servo compare to HITEC second is that it half the rated torque of the HITEC second i see that digital are programable where alogs are not i have a very good servo tester rated for one best on the market ,when i get a chance will do the test since the servo tester you are using uses just a cheap timer design,if you open it up will be 4 times,a 555 timer design uses 2 timer chips per channel and does not have high accuracy but still a fair good test one day i may buy another video camera,sold mine about 4 years ago,some hd digital by sony,since i havent used them for awhile only thing i did keep is my pro camera equipment ,(i love my digital rebel ,it can change any lens) plus my underwater camera take scuba diving
