Camera Variable Overlay icon Camera Variable Overlay — Overlay image packs onto camera feed and map images to control-variable ranges with auto/manual assignment, position and sizing options. Try it →
Help Needed With A Code
I have been trying to get this code to work,
#Power Up
ControlCommand("Script Manager", ScriptStart, "Amp On")
Sleep(500)
ControlCommand("Auto Release", PauseOn)
Sleep(2000)
ControlCommand("Auto Position 3", AutoPositionFrame, "Tilt Straight",100,7,4)
sleep(5000)
ControlCommand("Auto Position", AutoPositionFrame, "Rest",25,10,5)
Sleep(5000)
Sayezbwait("i am ready")
ControlCommand("Script Manager", ScriptStop, "LowPowerMonitoring")
sleep(500)
ControlCommand("Camera", CameraStart)
Sleep(500)
ControlCommand("Script Manager", ScriptStart, "Monitor")
The problem is the Auto PositionFrame "Rest" will not run,however, if I run the the code again, it will. I've played with various sleep duration's between lines in the code. I'm stumped ! Anyone got any ideas?
But, they work the second time you run the power up?
When I run it a second or third time the "Rest" servos run but not the "Tilt Straight" servos. Edit. Other servos on Board 1 work though.
Try this release: https://synthiam.com/Community/Questions/9129
When the servos are in the same position and the release is called, the servos do not go back into the same position due to locking into pwm timing. The latest software release should compensate for that.
Thanks DJ, That fixed it up, everything is working great now.
