Dual Hbridge icon Dual Hbridge — Two-channel Dual H-Bridge movement panel to control two DC motors (on/off) for forward, reverse, left, right via EZ-B digital ports; no PWM speed. Try it →
sorry. i'm not good with this stuff(12yrs).
to add an image from your computer you take the image, make sure its jpeg,jpg, and your click "attach a file" at the bottom left. click browse and select the image. then say upload.
to add an image from a website just copy and paste the link in "Add Image".
Thanks for the help. I found out the module is a surface mount and I ordered a breakout board to mount it to.
Steve3624-
Where did you get your break out board?
Netherlands
Twitter YouTube
@steve3624 What are you planning to use the BLK-MD-BC05-B for? It's a A2DP bluetooth audio module. This can't be connected to the EZ-B.
