Ohmnilabs Standalone icon Ohmnilabs Standalone — Connects Ohmnilabs Telepresence robot's UP Board COM to ARC, enabling drive and servo control (neck V0) and integration with ARC cameras. Try it →
Resolved Resolved by RobertL184!
Help Connecting A Neopixel Ring
Hello all,
Has anyone used a NeoPixel Ring before. I can't figure out how to wire it or connect it to EZB. Here is a link to the NeoPixel Ring site it has a data sheet. https://www.adafruit.com/product/1586
I have look at the I2C but not sure what address or how it is wired.
Thank you.
#65
If nothing with my code seems to make the neopixels work it may be that the neopixel data pin is different than what you have wire up.
The mulitasking code has a strand on pins 5,6, and 7
NeoPatterns Ring1(24, 5, NEO_GRB + NEO_KHZ800, &Ring1Complete); NeoPatterns Ring2(16, 6, NEO_GRB + NEO_KHZ800, &Ring2Complete); NeoPatterns Stick(16, 7, NEO_GRB + NEO_KHZ800, &StickComplete);
My code has the strand on pin 6
NeoPatterns Ring1(16, 6, NEO_GRB + NEO_KHZ800, &Ring1Complete);
So the first thing to check is that the NeoPattern Ring1 is being called with the correct pin number to match your wiring.
The second thing to note is that my code was hacked together to allow the EZ-B to control the neopixel strip. To get the arduino to light up the string you want to have the EZ-B send the arduino a command.
Like "F0,0,255,0,0,0,50,25,0" to have it do a fade.
The command for the EZ-B to do this is SendSerial(d0, 9600, "F0,0,255,0,0,0,50,25,0") assuming of course that the arduino is wired up to get serial data from the "d0" pin.
To try is you can use the serial monitor in the arduino IDE to send the serial string to the arduino.
If you don't want any serial control at all. The multitasking code should work for you.
#66
Here is a version of my code with the larson scanner fixed.
/* real time Serial Controlled Neopixel Ring  -- Code not tested yet
/ Serial Commands
/     Cr1,g1,b1  - Set whole Ring to same color specified by r1,g1,b1
/     Rt,d  - Rainbow  with interval t and direction d
/     Tr1,g1,b1,r2,g2,b2,t,d - Theater Chase between color r1,g1,b1 and color r2,g2,b2 with interval t and direction d
/     Wr1,g1,b1,t,d - Color Wipe in  color r1,g1,b1 with interval t and direction d
/     Fr1,g1,b1,r2,g2,b2,s,t,d - Fade between color r1,g1,b1 and color r2,g2,b2 in s steps with interval t and direction d
/     Sr1,g1,b1,t  - Scanner with color specified by r1,g1,b1 and interval t
/     Pp,r1,g1,b1 - Set individual pixel p to color specified by r1,g1,b1
/    p = pixel number
/    r1 = 1st color red values 0 to 255
/    g1 = 1st color greern values 0 to 255
/    b1 = 1st color blue values 0 to 255
/    r2 = 2nd color red values 0 to 255
/    g2 = 2nd color greern values 0 to 255
/    b2 = 2nd color blue values 0 to 255
/    s = number of steps
/    t = interval time values 0 to 255
/    d = direction  0 = Forward 1 = Backward
#include <Adafruit_NeoPixel.h>
// Pattern types supported:
enum  pattern { NONE, RAINBOW_CYCLE, THEATER_CHASE, COLOR_WIPE, SCANNER, FADE };
// Patern directions supported:
enum  direction { FORWARD, REVERSE };
// NeoPattern Class - derived from the Adafruit_NeoPixel class
class NeoPatterns : public Adafruit_NeoPixel
    public:
    // Member Variables:
    pattern  ActivePattern;  // which pattern is running
    direction Direction;     // direction to run the pattern
    unsigned long Interval;   // milliseconds between updates
    unsigned long lastUpdate; // last update of position
    uint32_t Color1, Color2;  // What colors are in use
    uint16_t TotalSteps;  // total number of steps in the pattern
    uint16_t Index;  // current step within the pattern
    void (*OnComplete)();  // Callback on completion of pattern
    // Constructor - calls base-class constructor to initialize strip
    NeoPatterns(uint16_t pixels, uint8_t pin, uint8_t type, void (*callback)())
    :Adafruit_NeoPixel(pixels, pin, type)
        OnComplete = callback;
    // Update the pattern
    void Update()
        if((millis() - lastUpdate) > Interval) // time to update
            lastUpdate = millis();
            switch(ActivePattern)
                case RAINBOW_CYCLE:
                    RainbowCycleUpdate();
                    break;
                case THEATER_CHASE:
                    TheaterChaseUpdate();
                    break;
                case COLOR_WIPE:
                    ColorWipeUpdate();
                    break;
                case SCANNER:
                    ScannerUpdate();
                    break;
                case FADE:
                    FadeUpdate();
                    break;
                default:
                    break;
    // Increment the Index and reset at the end
    void Increment()
        if (Direction == FORWARD)
           Index++;
           if (Index >= TotalSteps)
                Index = 0;
                if (OnComplete != NULL)
                    OnComplete(); // call the comlpetion callback
        else // Direction == REVERSE
            --Index;
            if (Index <= 0)
                Index = TotalSteps-1;
    // Reverse pattern direction
    void Reverse()
            Direction = REVERSE;
        else
            Direction = FORWARD;
            Index = 0;
//Completion Routines - get called on completion of a pattern
    // Initialize for a RainbowCycle
    void RainbowCycle(uint8_t interval, direction dir = FORWARD)
        ActivePattern = RAINBOW_CYCLE;
        Interval = interval;
        TotalSteps = 255;
        Index = 0;
        Direction = dir;
    // Update the Rainbow Cycle Pattern
    void RainbowCycleUpdate()
        for(int i=0; i< numPixels(); i++)
            setPixelColor(i, Wheel(((i * 256 / numPixels()) + Index) & 255));
        show();
        Increment();
    // Initialize for a Theater Chase
    void TheaterChase(uint32_t color1, uint32_t color2, uint8_t interval, direction dir = FORWARD)
        ActivePattern = THEATER_CHASE;
        TotalSteps = numPixels();
        Color1 = color1;
        Color2 = color2;
        Index = 0;
        Direction = dir;
    // Update the Theater Chase Pattern
    void TheaterChaseUpdate()
            if ((i + Index) % 3 == 0)
                setPixelColor(i, Color1);
            else
                setPixelColor(i, Color2);
        show();
        Increment();
    // Initialize for a ColorWipe
    void ColorWipe(uint32_t color, uint8_t interval, direction dir = FORWARD)
        ActivePattern = COLOR_WIPE;
        Color1 = color;
        Index = 0;
        Direction = dir;
    // Update the Color Wipe Pattern
    void ColorWipeUpdate()
        setPixelColor(Index, Color1);
        show();
        Increment();
    // Initialize for a SCANNNER
    void Scanner(uint32_t color1, uint8_t interval)
        ActivePattern = SCANNER;
        TotalSteps = (numPixels() - 1) * 2;
        Color1 = color1;
        Index = 0;
    // Update the Scanner Pattern
    void ScannerUpdate()
        for (int i = 0; i < numPixels(); i++)
            if (i == Index)  // Scan Pixel to the right
            else if (i == TotalSteps - Index) // Scan Pixel to the left
            else // Fading tail
                 setPixelColor(i, DimColor(getPixelColor(i)));
        show();
        Increment();
    // Initialize for a Fade
    void Fade(uint32_t color1, uint32_t color2, uint16_t steps, uint8_t interval, direction dir = FORWARD)
        ActivePattern = FADE;
        TotalSteps = steps;
        Color1 = color1;
        Color2 = color2;
        Index = 0;
        Direction = dir;
    // Update the Fade Pattern
    void FadeUpdate()
        // Calculate linear interpolation between Color1 and Color2
        // Optimise order of operations to minimize truncation error
        uint8_t red = ((Red(Color1) * (TotalSteps - Index)) + (Red(Color2) * Index)) / TotalSteps;
        uint8_t green = ((Green(Color1) * (TotalSteps - Index)) + (Green(Color2) * Index)) / TotalSteps;
        uint8_t blue = ((Blue(Color1) * (TotalSteps - Index)) + (Blue(Color2) * Index)) / TotalSteps;
        ColorSet(Color(red, green, blue));
        show();
        Increment();
    // Calculate 50% dimmed version of a color (used by ScannerUpdate)
    uint32_t DimColor(uint32_t color)
        // Shift R, G and B components one bit to the right
        uint32_t dimColor = Color(Red(color) >> 1, Green(color) >> 1, Blue(color) >> 1);
        return dimColor;
    // Set all pixels to a color (synchronously)
    void ColorSet(uint32_t color)
            setPixelColor(i, color);
        show();
    // Returns the Red component of a 32-bit color
    uint8_t Red(uint32_t color)
        return (color >> 16) & 0xFF;
    // Returns the Green component of a 32-bit color
    uint8_t Green(uint32_t color)
        return (color >> 8) & 0xFF;
    // Returns the Blue component of a 32-bit color
    uint8_t Blue(uint32_t color)
        return color & 0xFF;
    // Input a value 0 to 255 to get a color value.
    // The colours are a transition r - g - b - back to r.
    uint32_t Wheel(byte WheelPos)
        WheelPos = 255 - WheelPos;
        if(WheelPos < 85)
            return Color(255 - WheelPos * 3, 0, WheelPos * 3);
        else if(WheelPos < 170)
            WheelPos -= 85;
            return Color(0, WheelPos * 3, 255 - WheelPos * 3);
        else
            WheelPos -= 170;
            return Color(WheelPos * 3, 255 - WheelPos * 3, 0);
void Ring1Complete();
// Define some NeoPatterns for the two rings and the stick
//  as well as some completion routines
int red1 = 0;              // red value
int green1 = 34;           // green value
int blue1 = 12;            // blue value
int red2 = 0;              // red value
int green2 = 34;           // green value
int blue2 = 12;            // blue value
int my_pixel = 0;          // pixel number
int s = 5;                 // step value
int t = 10;                // interval time value
int d = 0;                  // direction indicator 0= Forward 1 = Backward
// Initialize everything and prepare to start
void setup()
  Serial.begin(9600);
  Serial.setTimeout(10);  // set serial timeout
    // Initialize all the pixelStrips
    Ring1.begin();
    Ring1.ColorSet(Ring1.Color(0, 0, 0));
// Main loop
void loop()
int inchar;
  if (Serial.available() > 0) {
    inchar = Serial.read();
    if ( inchar == 'C') {    // string should start with C
      red1 = Serial.parseInt();     // then an ASCII number for red
      green1 = Serial.parseInt();   // then an ASCII number for green
      blue1 = Serial.parseInt();    // then an ASCII number for blue
      Ring1.ActivePattern = NONE;
      Ring1.ColorSet(Ring1.Color(red1, green1, blue1));
    if ( inchar == 'R') {    // string should start with R
      t = Serial.parseInt();     // then an ASCII number for interval
      d = Serial.parseInt();    // then an ASCII number for direction
      if (d ==0) {
         Ring1.RainbowCycle(t, FORWARD);
      } else {
         Ring1.RainbowCycle(t, REVERSE);
    if ( inchar == 'F') {    // string should start with F
      red2 = Serial.parseInt();     // then an ASCII number for red
      green2 = Serial.parseInt();   // then an ASCII number for green
      blue2 = Serial.parseInt();    // then an ASCII number for blue
      s = Serial.parseInt();        // then an ASCII number for steps
      if (d ==0) {
        Ring1.Fade(Ring1.Color(red1, green1, blue1), Ring1.Color(red2, green2, blue2), s, t, FORWARD);
      } else {
        Ring1.Fade(Ring1.Color(red1, green1, blue1), Ring1.Color(red2, green2, blue2), s, t, REVERSE);
    if ( inchar == 'T') {    // string should start with T
      if (d ==0) {
        Ring1.TheaterChase(Ring1.Color(red1, green1, blue1), Ring1.Color(red2, green2, blue2), t, FORWARD);
      } else {
        Ring1.TheaterChase(Ring1.Color(red1, green1, blue1), Ring1.Color(red2, green2, blue2), t, REVERSE);
    if ( inchar == 'W') {    // string should start with W
      if (d ==0) {
        Ring1.ColorWipe(Ring1.Color(red1, green1, blue1), t, FORWARD);
      } else {
        Ring1.ColorWipe(Ring1.Color(red1, green1, blue1), t, REVERSE);
    if ( inchar == 'S') {    // string should start with S
      Ring1.ColorWipe(Ring1.Color(red1, green1, blue1), 50, 0);
      Ring1.ColorSet(Ring1.Color(0,0, 0));
      Ring1.Scanner(Ring1.Color(red1, green1, blue1), t);
     if ( inchar == 'P') {    // string should start with P
      my_pixel = Serial.parseInt();     // then an ASCII number for pixwel
      Ring1.setPixelColor(my_pixel, Ring1.Color(red1, green1, blue1));
      Ring1.show();
  // Update the ring.
    Ring1.Update();
// Ring1 Completion Callback
  if ((Ring1.ActivePattern == RAINBOW_CYCLE) || (Ring1.ActivePattern == FADE) ||
      (Ring1.ActivePattern == THEATER_CHASE) || (Ring1.ActivePattern == SCANNER)){
    Ring1.Reverse();
I haven't tried the updated code with CochranRobotics EZ-B Plugin.
#67
If you really want to use my code and don't want any serial input you need to replace the main loop with something like this:
void loop()
      red1 = 255;     // for red
      green1 = 0;   //  for green
      blue1 = 0;    //  for blue
      red2 = 0;     //  for second red
      green2 = 255;   // for second green
      blue2 = 0;    // for second blue
      t=100;
Modify the variables:
red1, green1, blue1, red2, blue2, green2, and t for the colors and delay time you want.
I haven't complied the code above so don't know as it will work without some debugging.
You didn't mention where you put the code to read you potentiometer and set the Brightness in the multitasking code, but you could most likely put it in the same place in my code. It is based on the multitasking code.
Remember setting the strand brightness reduces the number of colors available for the entire strand. The same effect can be had for most of the routines my simply changing the red1, green1, blue1, red2, blue2, green2 variable to smaller values. The exception to this is the rainbow routine which uses all of the colors. For that one routine the Brightness setting would work best.
#68
@RobertL184
Robert, Thank you for all your feedback and I will re-check the Arduino pin connection, but I am certain that is not the cause. When I change the
Ring1.ColorSet(Ring1.Color(0, 0, 0)); to Ring1.ColorSet(Ring1.Color(20, 0, 0));
the ring lights up. Also, I put few println in the code for sanity check and I see the output is the SUI.
Below is the code I added to yours and Arduino multi-tasking part-3 for the potentiometer and I know it works with the latter. The ints are placed under the NeoPatterns line and the rest is placed within the loop. I have Ring1,Ring2 and Stick for the Arduino multi-tasking and only Ring1 for your code.
int potPin                = A0; // Potentiometer input
int potVal                 =  0; // Potentiometer value
int ringBrightness  =  0; // Brightness of LEDs
int lastpot                =  0; // last potentiometer reading to compair with
// Main loop
void loop()
  potVal = analogRead(potPin);
  if ( potVal != lastpot ) {
    lastpot = potVal;
    ringBrightness = map(potVal, 0, 1023, 0, 250);
    Ring1.setBrightness(ringBrightness);
I will let you once I get everything working.
#69
I've been trying to load the code from post # 37 and I get a bunch of error messages. It worked when it was first posted but I can get it to load now. Could someone try loading it and see if it works. Maybe it's my system, I don't know.
Thanks
#70
To download this version of the Arduino IDE ==> (previous versions link)
I think it was 1.6.4 that I used back then but it has been a while since I have looked.
I think what is happening is that you have to use a previous version of the Arduino IDE in order to compile the code from that long ago. I think the link above will take you to the version that you would have to use. The later post should work with a more current version of the IDE.
#71
From my plugin that uses this code...
"The code below works with Arduino IDE 1.6.3 with the 1.0.3 version of the Adafruit NeoPixel library,"
#72
Thanks Dave. I installed Arduino IDE 1.6.3 and the sketch loaded OK and works good.
