TCP Script Server Raw icon TCP Script Server Raw — TCP server for ARC accepting EZ-Script, JavaScript or Python commands, letting controllers send commands and receive line-terminated responses Try it →
Resolved Resolved by RobertL184!
Help Connecting A Neopixel Ring
Hello all,
Has anyone used a NeoPixel Ring before. I can't figure out how to wire it or connect it to EZB. Here is a link to the NeoPixel Ring site it has a data sheet. https://www.adafruit.com/product/1586
I have look at the I2C but not sure what address or how it is wired.
Thank you.
#33
Thanks Robert. I will check it out and see where it leads.
#34
@RobertL184, can you post an example of the fix you have for this?
#35
I should have my parts tomorrow (unless something happens in shipping). I will work on this some time soon and post my script and how I have things wired up. I plan on using some of the things posted by Robert in his last post and using a digital pin from the V4 to a digital pin on the arduino as an interrupt when serial communication starts and stops which will allow the arduino to know to interrupt its loop and catch the serial communication from the V4 which will set which color you want to have pulse again.
#36
Okay here is a total untested shot at the code for a single neopixel with animations which should be fairly responsive to serial commands. I haven't had time to test any of it. All I can say is that it does compile. The code is mainly from adafruit lesson number 3. It will probably need a bit more work to make everything function properly. The Ring1Complete function is the one I am least sure of.
/* real time Serial Controlled Neopixel Ring  -- Code not tested yet
/ Serial Commands
/     Cr1,g1,b1  - Set whole Ring to same color specified by r1,g1,b1
/     Rt,d  - Rainbow  with interval t and direction d
/     Tr1,g1,b1,r2,g2,b2,t,d - Theater Chase between color r1,g1,b1 and color r2,g2,b2 with interval t and direction d
/     Wr1,g1,b1,t,d - Color Wipe in  color r1,g1,b1 with interval t and direction d
/     Fr1,g1,b1,r2,g2,b2,s,t,d - Fade between color r1,g1,b1 and color r2,g2,b2 in s steps with interval t and direction d
/     Sr1,g1,b1,t  - Scanner with color specified by r1,g1,b1 and interval t
/     Pp,r1,g1,b1 - Set individual pixel p to color specified by r1,g1,b1
/    p = pixel number
/    r1 = 1st color red values 0 to 255
/    g1 = 1st color greern values 0 to 255
/    b1 = 1st color blue values 0 to 255
/    r2 = 2nd color red values 0 to 255
/    g2 = 2nd color greern values 0 to 255
/    b2 = 2nd color blue values 0 to 255
/    s = number of steps
/    t = interval time values 0 to 255
/    d = direction  0 = Forward 1 = Backward
#include <Adafruit_NeoPixel.h>
// Pattern types supported:
enum  pattern { NONE, RAINBOW_CYCLE, THEATER_CHASE, COLOR_WIPE, SCANNER, FADE };
// Patern directions supported:
enum  direction { FORWARD, REVERSE };
// NeoPattern Class - derived from the Adafruit_NeoPixel class
class NeoPatterns : public Adafruit_NeoPixel
    public:
    // Member Variables:
    pattern  ActivePattern;  // which pattern is running
    direction Direction;     // direction to run the pattern
    unsigned long Interval;   // milliseconds between updates
    unsigned long lastUpdate; // last update of position
    uint32_t Color1, Color2;  // What colors are in use
    uint16_t TotalSteps;  // total number of steps in the pattern
    uint16_t Index;  // current step within the pattern
    void (*OnComplete)();  // Callback on completion of pattern
    // Constructor - calls base-class constructor to initialize strip
    NeoPatterns(uint16_t pixels, uint8_t pin, uint8_t type, void (*callback)())
    :Adafruit_NeoPixel(pixels, pin, type)
        OnComplete = callback;
    // Update the pattern
    void Update()
        if((millis() - lastUpdate) > Interval) // time to update
            lastUpdate = millis();
            switch(ActivePattern)
                case RAINBOW_CYCLE:
                    RainbowCycleUpdate();
                    break;
                case THEATER_CHASE:
                    TheaterChaseUpdate();
                    break;
                case COLOR_WIPE:
                    ColorWipeUpdate();
                    break;
                case SCANNER:
                    ScannerUpdate();
                    break;
                case FADE:
                    FadeUpdate();
                    break;
                default:
                    break;
    // Increment the Index and reset at the end
    void Increment()
        if (Direction == FORWARD)
           Index++;
           if (Index >= TotalSteps)
                Index = 0;
                if (OnComplete != NULL)
                    OnComplete(); // call the comlpetion callback
        else // Direction == REVERSE
            --Index;
            if (Index <= 0)
                Index = TotalSteps-1;
    // Reverse pattern direction
    void Reverse()
            Direction = REVERSE;
        else
            Direction = FORWARD;
            Index = 0;
    // Initialize for a RainbowCycle
    void RainbowCycle(uint8_t interval, direction dir = FORWARD)
        ActivePattern = RAINBOW_CYCLE;
        Interval = interval;
        TotalSteps = 255;
        Index = 0;
        Direction = dir;
    // Update the Rainbow Cycle Pattern
    void RainbowCycleUpdate()
        for(int i=0; i< numPixels(); i++)
            setPixelColor(i, Wheel(((i * 256 / numPixels()) + Index) & 255));
        show();
        Increment();
    // Initialize for a Theater Chase
    void TheaterChase(uint32_t color1, uint32_t color2, uint8_t interval, direction dir = FORWARD)
        ActivePattern = THEATER_CHASE;
        TotalSteps = numPixels();
        Color1 = color1;
        Color2 = color2;
        Index = 0;
        Direction = dir;
    // Update the Theater Chase Pattern
    void TheaterChaseUpdate()
            if ((i + Index) % 3 == 0)
                setPixelColor(i, Color1);
            else
                setPixelColor(i, Color2);
        show();
        Increment();
    // Initialize for a ColorWipe
    void ColorWipe(uint32_t color, uint8_t interval, direction dir = FORWARD)
        ActivePattern = COLOR_WIPE;
        Color1 = color;
        Index = 0;
        Direction = dir;
    // Update the Color Wipe Pattern
    void ColorWipeUpdate()
        setPixelColor(Index, Color1);
        show();
        Increment();
    // Initialize for a SCANNNER
    void Scanner(uint32_t color1, uint8_t interval)
        ActivePattern = SCANNER;
        TotalSteps = (numPixels() - 1) * 2;
        Color1 = color1;
        Index = 0;
    // Update the Scanner Pattern
    void ScannerUpdate()
        for (int i = 0; i < numPixels(); i++)
            if (i == Index)  // Scan Pixel to the right
            else if (i == TotalSteps - Index) // Scan Pixel to the left
            else // Fading tail
                 setPixelColor(i, DimColor(getPixelColor(i)));
        show();
        Increment();
    // Initialize for a Fade
    void Fade(uint32_t color1, uint32_t color2, uint16_t steps, uint8_t interval, direction dir = FORWARD)
        ActivePattern = FADE;
        TotalSteps = steps;
        Color1 = color1;
        Color2 = color2;
        Index = 0;
        Direction = dir;
    // Update the Fade Pattern
    void FadeUpdate()
        // Calculate linear interpolation between Color1 and Color2
        // Optimise order of operations to minimize truncation error
        uint8_t red = ((Red(Color1) * (TotalSteps - Index)) + (Red(Color2) * Index)) / TotalSteps;
        uint8_t green = ((Green(Color1) * (TotalSteps - Index)) + (Green(Color2) * Index)) / TotalSteps;
        uint8_t blue = ((Blue(Color1) * (TotalSteps - Index)) + (Blue(Color2) * Index)) / TotalSteps;
        ColorSet(Color(red, green, blue));
        show();
        Increment();
    // Calculate 50% dimmed version of a color (used by ScannerUpdate)
    uint32_t DimColor(uint32_t color)
        // Shift R, G and B components one bit to the right
        uint32_t dimColor = Color(Red(color) >> 1, Green(color) >> 1, Blue(color) >> 1);
        return dimColor;
    // Set all pixels to a color (synchronously)
    void ColorSet(uint32_t color)
            setPixelColor(i, color);
        show();
    // Returns the Red component of a 32-bit color
    uint8_t Red(uint32_t color)
        return (color >> 16) & 0xFF;
    // Returns the Green component of a 32-bit color
    uint8_t Green(uint32_t color)
        return (color >> 8) & 0xFF;
    // Returns the Blue component of a 32-bit color
    uint8_t Blue(uint32_t color)
        return color & 0xFF;
    // Input a value 0 to 255 to get a color value.
    // The colours are a transition r - g - b - back to r.
    uint32_t Wheel(byte WheelPos)
        WheelPos = 255 - WheelPos;
        if(WheelPos < 85)
            return Color(255 - WheelPos * 3, 0, WheelPos * 3);
        else if(WheelPos < 170)
            WheelPos -= 85;
            return Color(0, WheelPos * 3, 255 - WheelPos * 3);
        else
            WheelPos -= 170;
            return Color(WheelPos * 3, 255 - WheelPos * 3, 0);
// Define some NeoPatterns for the two rings and the stick
//  as well as some completion routines
NeoPatterns Ring1(16, 6, NEO_GRB + NEO_KHZ800, &Ring1Complete);
int red1 = 0;              // red value
int green1 = 34;           // green value
int blue1 = 12;            // blue value
int red2 = 0;              // red value
int green2 = 34;           // green value
int blue2 = 12;            // blue value
int my_pixel = 0;          // pixel number
int s = 5;                 // step value
int t = 10;                // interval time value
int d = 0;                  // direction indicator 0= Forward 1 = Backward
// Initialize everything and prepare to start
void setup()
  Serial.begin(9600);
  Serial.setTimeout(10);  // set serial timeout
    // Initialize all the pixelStrips
    Ring1.begin();
    Ring1.ColorSet(Ring1.Color(0, 0, 0));
// Main loop
void loop()
int inchar;
  if (Serial.available() > 0) {
    inchar = Serial.read();
    if ( inchar == 'C') {    // string should start with C
      red1 = Serial.parseInt();     // then an ASCII number for red
      green1 = Serial.parseInt();   // then an ASCII number for green
      blue1 = Serial.parseInt();    // then an ASCII number for blue
      Ring1.ActivePattern = NONE;
      Ring1.ColorSet(Ring1.Color(red1, green1, blue1));
    if ( inchar == 'R') {    // string should start with R
      t = Serial.parseInt();     // then an ASCII number for interval
      d = Serial.parseInt();    // then an ASCII number for direction
      if (d ==0) {
         Ring1.RainbowCycle(t, FORWARD);
      } else {
         Ring1.RainbowCycle(t, REVERSE);
    if ( inchar == 'F') {    // string should start with F
      red2 = Serial.parseInt();     // then an ASCII number for red
      green2 = Serial.parseInt();   // then an ASCII number for green
      blue2 = Serial.parseInt();    // then an ASCII number for blue
      s = Serial.parseInt();        // then an ASCII number for steps
      if (d ==0) {
        Ring1.Fade(Ring1.Color(red1, green1, blue1), Ring1.Color(red2, green2, blue2), s, t, FORWARD);
      } else {
        Ring1.Fade(Ring1.Color(red1, green1, blue1), Ring1.Color(red2, green2, blue2), s, t, REVERSE);
    if ( inchar == 'T') {    // string should start with T
      if (d ==0) {
        Ring1.TheaterChase(Ring1.Color(red1, green1, blue1), Ring1.Color(red2, green2, blue2), t, FORWARD);
      } else {
        Ring1.TheaterChase(Ring1.Color(red1, green1, blue1), Ring1.Color(red2, green2, blue2), t, REVERSE);
    if ( inchar == 'W') {    // string should start with W
      if (d ==0) {
        Ring1.ColorWipe(Ring1.Color(red1, green1, blue1), t, FORWARD);
      } else {
        Ring1.ColorWipe(Ring1.Color(red1, green1, blue1), t, REVERSE);
    if ( inchar == 'S') {    // string should start with S
      Ring1.Scanner(Ring1.Color(red1, green1, blue1), t);
     if ( inchar == 'P') {    // string should start with P
      my_pixel = Serial.parseInt();     // then an ASCII number for pixwel
      Ring1.setPixelColor(my_pixel, Ring1.Color(red1, green1, blue1));
      Ring1.show();
  // Update the ring.
    Ring1.Update();
//Completion Routines - get called on completion of a pattern
// Ring1 Completion Callback
void Ring1Complete()
  if ((Ring1.ActivePattern == RAINBOW_CYCLE) || (Ring1.ActivePattern == FADE) ||
      (Ring1.ActivePattern == THEATER_CHASE) || (Ring1.ActivePattern == SCANNER)){
    Ring1.Reverse();
#37
Thank you Robert. I will give it a shot tonight and post any modifications that I make to it.
#38
Thanks Robert, I just uploaded and ran your code. First thought I had to define the pin #. 'F' and 'R' work the others don't, the pixels are dark. I'll play with it.
#39
I just tested and it is working great. Thank you Robert. This is very nice. I used 1 for right I believe. This will make a lot of EZ-Robot InMoov owners very happy.
Just to be clear of how I have everything wired up...
V4 D0 is connected to RX1 on the arduino mini pro
Ground from the Arduino mini pro is wired to the neopixel ground.
Pin 6 from the Arduino mini pro is wired to the neopixel data in.
  • Power to the neopixel and the Arduino is running from a voltage regulator that reduces from 12 V to 5 V.
  • power to the Arduino is connected to the voltage regulator.
In ARC I have tested these different modes. They are cool. You wouldn't just want to run this script as it would probably flash the neopixel and then go black. These are some examples of how to use it.
#White light
SendSerial(d0, 9600, "C100,100,100")
#Ring rotating to the right
SendSerial(d0, 9600, "R10,1")
#fade from black to red
SendSerial(d0, 9600, "F255,0,0,0,0,0,50,2000,1")
#Turn off neopixel
SendSerial(d0, 9600, "C0,0,0")
#40
@ d.cochrane, did all of it work?
