I'm a complete rookie when it comes to robotics but, I'm willing to learn. I'm about to find out if an "old dog" can learn new tricks. I'm fully retired for about 6 yrs now and loving it. I have experience with RC airplanes, helicopters, and a few cars and digitally controlled model trains. I know a bit about the hardware of computers but, the software boggles my mind and that's why I'm so excited about E-Z Robot. It appears that Mr. Sures has taken the hard part out of the programming by providing an easy to use programming suite.
I'm really excited about the mods/hacks associated with "toy" robots and plan to easy. Since Mr. Sures has done all of the hard work for us, I'm looking very strongly into the Wow Wee selection of bots. I follow instructions pretty well and the tutorial videos I've watched make it look pretty darned simple.
I'm looking forward to learing from this group and I hope you will all forgive my occasional dumb question.
RJ Arlington, TX
Awesome guys. With this kind of help and cooperation, how can we go wrong?
Can hardly wait for the EZb V4 release. My RS 1 is patiently waiting. I've been driving my two small dogs crazy with him. They don't like him at all so, my "play time" is limited to the amount of loud barking my ears can withstand. This problem may play havoc with voice commands? I wonder if they sell "dog noise cancelling" microphones?
Update on the V2 second rewire attempt .... I've successfully replaced the 6 pin connector harness and buttoned up the left side. I have the 7 pin connector wired but, not installed as yet. I hope to do that this weekend. I've found that it's much easier to work on him if I remove the leg I'm working on. Once the upper outside cover is removed, there are two screws that hold the leg in place. Remove those screws and the then the leg to give you much easier access.
By the way ...if anyone is considering buying a new 7 pin connector to replace the original one, be sure to buy the terminal pins in a 100 piece strip (about $2 us). They come attached to a metal strip and are much easier to handle during wire installation if the "tab" is left in place until the wire is firmly attached. I found that a small pair of medical clamps (forceps?) very useful for clamping the wire to the terminal. It's time consuming but, it can be done if you are dedicated to the repair. It is possible to solder the wire to the connectors but, you must use a small tip on your iron and very tiny amount of solder. Either way, the "tab" on the pin is a great aid in holding it until the job is done.
RJ
rowdyjoe.that was not a good idea to remove the leg from the hip.they break easly.
Thanks for the warning Nomad. I'll be sure to be careful.
Which parts are so delicate? They all look very sturdy to me. The leg "bones" fit closely onto the hip pins but, can be worked loose easily if careful. Just wiggle gently with upward pressure until they slide off the pins. A drop of thin machine oil will help if they are stubborn but, I haven't found the need for that yet. Obviously, you don't want to try to pry them off with anything as it's not necessary and the plastic "bones" can break.
RJ
the plastik where these screws go in.break easly off.
