Movement Script icon Movement Script — Trigger direction-specific scripts when ARC movement panels change; assign scripts per direction/stop, access direction and speed (JS/Python/EZ). Try it →
Hacked A Spykee
The Spykee was kinda lousy as a robot, limited, never updated and i was starting to think i wasted my money on it years ago. . . so. . . since I liked the spykee tracks. . ., it already had motors. . . and i had one laying around, my son and I Cracked it open, stripped out all the electronics, hooked up 2 tazer 10T ESC's to the motors and stacked an erector platform to the top, mounted the ezb, some batteries and off i go. . .
I'm a programmer by trade, so writing a VB script was second nature. My son (14 yo) and I talked about what we wanted it to do and I scripted it out (he's learning).
Our avoidance script works pretty well . . but I'm wodering if the sharp IR sensor would be more accurate/reliable. . . it seems the ping sensor sometimes returns values it shouldn't (0 or 255, then the next one is correct, etc). . . perhaps it's due to a ping-lag, not sure.
I tried using the ping radar control, it worked but wan't smart enough for me.
So my script does this:
Variables: Min servo, max servo, granularity, min distance, granularity, safe distance
first i calculate the servo positions up front and store them in an array ((max servo - minservo) / granularity) rather than "plussing" the servo position, i just tell it to "go to position 1" etc.
THEN:
  1. move forward while scanning back and forth looking for min distance or less.
on min distance (or less): 2) STOP 3) randomly pick a new direction to turn (left or right) 4) turn (200ms) 5) STOP 6) scan once to get distance, 7) if distance > safe distance go to 1) 8) if distance <= safe distance go to 4)
Note. . . when turning right, start scanning left to right, as soon as you find min, return (may not do a full scan, but it's more efficient that way). Obviously opposite when turning left!
So i'm wondering if the sharp distance sensor would be quicker and more reliable? Any Thoughts? i would LOVE a LASER distance sensor to exist!
I have found a combination of sharp IRs AND sonic Pings work best for me.
do you have them on servo's or fixed?
I would love to see that. It was originally spykee that made me want to make a replacement....
