Hello ,
I have configured an HBridge PWM Movement skill on my EZ-B v4 with the following settings:
- Left Trigger A: Port 0.D21
- Right Trigger B: Port 0.D22
- PWM: Port 0.D23
When I measure the PWM output on my oscilloscope at port 0.D23, the signal appears perfect, and everything functions smoothly when I adjust the skill's slider.
However, I'm encountering an issue with the directional control signals. There is no signal output on Trigger A (0.D21) and Trigger B (0.D22) to control the direction. The signal remains flat at 0, regardless of the direction I select using the skill's directional arrows.
This seems like a basic setup, and I have successfully used this skill in the past. I am unsure what I might have overlooked. What could be causing this issue? I even tested with another EZ-B v4, suspecting a possible fault with the first one, but the behavior remains the same. It seems the problem is on my end, but I can't pinpoint where.
Any insights or suggestions would be greatly appreciated. Thank you!
Thanks! I was beginning to seriously doubt my abilities...
We were able to confirm this behavior. There will be an update which will include this fix. We’ll push it through as a priority release in the next few days.
Thank you for your quick follow-up!
I tried the fix and it works. Its pushed into qa for testing. Probably be online in the next day or two
I just tested with the new version v2024.12.16.00 and it works!
Excellent! Thank you!
Resolved with the new version v2024.12.16.00
