PWM Servo Ramping icon PWM Servo Ramping — Smoothly ramps PWM servos on EZB D0-D23 via Vx-to-Dx mapping for natural, gradual motion without snapping. Try it →
Thank you Frank, very much! I appreciate the positive feedback :):):)
@JustinRatliff I was able to run all of your examples without any issues, but when I used my own data I had some problems with a feature of Split()
A string consisting of alpha chars or mixed alpha and numeric work as I expected, but a string of just numbers is treated as math. This is by design according to an old post I found
Here is some code and the results showing the issue I can into:
ClearVariables()
$Chars= ("A,B,C")
$CharsSplit= Split( $Chars, "," ,  0 )
Print( "$CharsSplit= " + $CharsSplit)
$Numbers= ("1,2,3")
$NumbersSplit= Split( $Numbers, "," ,  0 )
Print( "$NumbersSplit= " + $NumbersSplit)
I was able to solve my problem by adding one field of alpha to my numeric data.
It might be helpful to add a caution to your great tutorial
Also, it appears that the Script manual states that Split() returns an index instead of the value found
https://synthiam.com/Tutorials/UserTutorials/169/1
Thanks again for your fine work on the tutorial Frank
A number is a number and a string is a string. A number is not a string because a number is used for math. Math uses numbers, not strings. So if you put a number in a variable, the type becomes a number. However, you can still parse/split a list of numbers by adding commas and using the split() command.
$x = "1, 2, 3, 4"
$val = split($x, ",", 2)
print($val)
*note: i updated the EZ-Script manual to reflect the misprint for Split(), thanks!
@DJSures Thanks for clearing that up! I did have the commas, neglected to add a spaces as you did in your example
I ran a test and adding the spaces to my code worked and I found out there was no need for the parentheses
ClearVariables()
$x = "1, 2, 3, 4"  # note the spaces
$val = split($x, ",", 3)
print($val)
$x= "1,2,3" # note NO spaces
$val= Split( $x, "," ,  0 )
Print( $val)
$x= "1 ,2, 3"  # added spaces
$val = split($x, "," ,  0 )
Print( $val)
$x= ("1, 2, 3") # added space and parentheses
Print( $val)
Thanks for the quick response Frank
