Getrss icon Getrss — Fetch RSS via GetRSS command; populates $RSSSuccess, $RSSErrorMsg and arrays $RSSTitles, $RSSDescriptions, $RSSLinks, $RSSDates for scripts. Try it →
Opening from ezcloud?
Hi DJ, thanks for the quick reply, I am opening from my project in ARC.
I at one time my project was on the ez cloud, I deleted it some time back. I did not see it when click on the icon.
Are you using the file open option in ARC or double clicking the file?
@DJ, double clicking I will try opening ezb first
Try opening the file through ARC using the File->open process.
It appears that another application may be attempting to open the file when it is double clicked. That is called file association. Another program has been associated with the file. There will be a method of selecting the file association for the version of your operating system.
Ok I opened ezb first then clicked open and selected my ezb file and I get the same result. I will look at the file Association. I can upload my project if you like?
Thanks DJ
If the same error occurs when opening from within ARC, it is not file association. Best to post your project.
Yeah upload your file to here please
