ZacharyC
I encountered an error today within Synthiam ARC when attempting to open the Speech Recognition control. The error message began with:
"Voice recognition was not able to start. System.Exception: Speech recognition is not supported due to an invalid operating system or missing device."
A screenshot has been added below for the full error message:
Additionally, the Speech Recognition window displayed a gray box where the microphone waveform was supposed to be; no red or green waveform was shown. Despite this, it was evident that ARC was not at fault, as the Microphone window continued to function correctly.
The issue was traced back to the default Language Pack in Windows (specifically, English US) not being installed. After installing the language pack, speech recognition resumed working without issue.
For anyone else experiencing this problem, here's how you can install the language pack:
- Click on the Start button, then navigate to Settings.
- Select Time & Language.
- On the left sidebar, click on Language.
- Select one of the Preferred Languages listed. (Note: If the language you need is not visible, a tutorial on how to install it can be found at Step 6 here: Speech Recognition Installation.)
- Click on Options.
- Under Language Pack at the top, click Install (or Download, as stated in the dialog).
I'm sharing this solution for others who might encounter the same issue.
@DJ If you think this information would be useful elsewhere on the website, feel free to place it wherever it seems appropriate, perhaps in the troubleshooting section at the following link: Synthiam Support - Camera, Audio and Microphone Issues.
Thanks - this is a great find and an excellent write-up. Your diagnosis and solution are exactly what others will need when ARC reports: "Speech recognition is not supported due to an invalid operating system or missing device."
Short summary (for anyone scanning):
Useful links
Step-by-step: install the Windows speech language (expanded)
Why the gray waveform happens
Extra tips
Would you confirm:
If you want, I can format your steps + screenshot into a short "Troubleshooting" post and point people to it on the community/support page - want me to do that?
Great find, however, the information is incorrect. The issue you experienced is because a language pack that does not support speech recognition was installed. According to Microsoft Windows documentation, speech recognition requires a supported language pack. Not all language packs support speech recognition. The speech recognition manual has more information on your question. Can you access the robot skills manuals by pressing the? (question mark) icon on the robot skill. You will find that icon next to the X (close) on each robot skill.
Good catch - thanks for the clarification. Synthiam_Support is correct: the root cause is not simply "missing a language pack" but installing a language pack that does NOT include Windows speech support. Not all Windows language packs include the Speech component, and Microsoft only enables speech recognition for supported languages.
Quick summary of the difference
What to check / step-by-step
Accessing the robot skill manuals & config
Useful links
Would you please confirm:
If you like, I can turn your original write-up into a short troubleshooting post that emphasizes "install a language pack that supports speech" (and include the steps above). Want me to prepare that?
hi all
remember win10 is no longer updateble .
Good reminder - thanks, Nomad_6R. A few clarifications and practical points for anyone using ARC Speech Recognition:
Quick checklist if you (or someone reading) are worried about speech on Windows 10:
Helpful Synthiam docs:
Would you (or Nomad_6R) share which Windows build you’re running and whether you’re seeing any ARC errors? I can help diagnose further or draft a short troubleshooting note to add to the Synthiam support resources.
@athena
can it be diff voor usa and belgium ?
Yes - it can definitely be different between the USA and Belgium. Windows speech recognition depends on the exact speech language that is installed and available on your system, and not every Windows language pack (or regional variant such as nl-BE / fr-BE) includes a speech component. In short: some language packs support Microsoft Speech, others do not - so behavior can vary by country / language variant.
What to check (quick steps)
Check Speech language in Windows
Check the language pack + Speech component
Install a supported speech language (test with enUS)
Test native Windows speech first
Check ARC Speech Recognition settings
Microphone privacy and permissions
Why Belgium vs USA can differ
If you want me to help further
Useful links
Want me to create a short step-by-step you can post in the community (emphasizing "install a language pack that supports speech")?
