Watson Speech To Text icon Watson Speech To Text — Watson Speech-to-Text ARC plugin: cloud AI transcription with configurable models, selectable VAD (Windows/WebRTC), audio capture and visualization. Try it →
Germany
Firmware Update Questions V2->v16
Firmware Update Questions V2->V16
Hi DJ & EZ-Robot community,
I have problems updating the firmware on my two EZ-B boards. I have a stable bluetooth connection and started the updater, but on both boards it stucks after these messages:
Attempting connection to COM40
EZ-B reports EZ-B Firmware V2
Connected
Starting Boot Loader...
sending ping
sending ping
sending bootloader
I am EZ-B BootLoader. Gimmie Firmware!
Updating... (22.656 Bytes)
After waiting for more than 5 minutes I have switched off the board and the EZ-B controller boots up with the old V2 firmware. Some more remarks: Batteries are fresh, nothing is connected to the ports. I have even tried a direct connection from my USB->Serial adapter (FTDI chipset) to the RxD/TxD/GND pins on the EZ-B base board, but got the same result... Tested on a Win7/64-Bit and Win XP/32 bit computer...
What can I do now ? Is there anything, which I can test/enable/measure ?
Thank you for your help :-)
Arne
P.S. Yes, I have seen the FW update tutorial...
Germany
I have added a video of the update procedure here: EZB-FW-Update_problem.zip
Maybe you can send me the firmware as binary + the exact part type via email and I will try to flash it with our external flash tools.
I have been having the same problem also. any fix yet ?
Germany
@DJ: Is there anything I can do to support your debugging of this issue ? I am currently stuck with my work and can't go on without the firmware update... Therefore I would be happy to test any kind of new alpha/beta version or log any data for you...
You can't flash by programming the chip. It needs to be programmed by the bootloader. I'm going to watch your video now and see what is happening...
Have you configured the serial settings? Have you changed anything? There is really something different about your computer that is causing the issue.
The progress bar is moving way too fast. It should take over one minute. This leads me to think there is a utility installed on your two computers that affects the serial communication.
  1. Are you certain Windows is not running in a virtual emulator, such as VMWare or Parallels?
  2. Visit the Device Manager and verify you have TWO communication ports for the EZ-B. When adding the EZ-B over bluetooth, TWO communication ports should be detected.
  3. What are the hardware specifications of your computer? CPU type, speed and architecture (32 or 64?)
  4. Visit the Device Manager and ensure the TWO EZ-B communication ports have the following default configuration:
Port Settings
Port Settings -> Advanced
Driver -> Driver Details
The communication with the EZ-B is fine until it begins sending the firmware. The firmware is being sent at a rate much faster than 9600, based on the progress bar of your video.
I may ask to for a screenshot of your "Programs and Features" list of installed software. The EZ-B will work on one your neighboors computer, just not yours - because something is installed or configured to affect the Serial Communication.
Even if you had the EZ-B firmware updated and working on a different computer, it will not work on yours. This is because there is a timing issue with the Serial Communication - it is clear in the progress bar video. There is something installed or configured that is affecting the serial port communication timing.
Germany
  1. YES ! (see my previous posts...)
  2. It has detected two COM ports
  3. Dell E5420 (Win7 / 64 Bit) + Dell D630 (Win XP, 32 Bit)
  4. My new laptop does not have a bluetooth module, therefore I am using the USB->Serial adapter. It is set to 9600,8N1. My old laptop has a Toshiba bluetooth module, where I can't set the baud rate. But if I look into the logs, I see, that your application is setting the baudrate to 9600, isn't it ?
And to be honest: EZ-B and FW updater are communicating, the bootloader is transmitted correctly, therefore I don't believe in a communication problem. Maybe you could have a look in your firmware update program, if the baudrate is changed just before the firmware data is transmitted or if there are any other settings changed. If the baudrate is not fixed in hardware/drivers a software could change the baudrate and mess up things. Just my guess...
#15
Again sorry to see your frustration. Please focus on my previous statement regarding the progress bar time. The progress bar is moving too quick in the helpful video you posted. The computer is sending the data too quicky. Some installed utility may be affecting the communication.
Please post a screenshot of the driver details and configuration of the Bluetooth enabled computer.
As I stated, it is not an issue with the ez-b. I am certain of that. The progress bar is moving too quickly as it should take 3 times as long.
Again, there are thousands of ez-b's used daily over the world. We will solve your specific issue, but I will need you to read my responses fully and feel free to ask about any statements that you not understand. We'll solve the issue:)
To begin, I'm going to make a special firmware updater for you. It will have some more debug information that will help. I will post it on here in a few hours:)
Germany
#16
@DJ: No offense, I really appreciate your fantastic work ! :) I am looking forward to your debug build tomorrow morning... ;) Lets investigate the cause for this issue !
