Ezb 4 And Pulse Out For A Chopper Drive
So Im wondering if the ezb4 will have a command for pulse output. I need 5vdc pulses to the tune of some 20,000 pulses. Less pulses , less travel. More pulses ,more travel. Im not concerned about resolution. Or would I need to write a script and loop the script the required amount of times for the required amount of travel. Will the EZB 4 put out 5vdc out of any of its ports? I will be powering everything from 1 sla battey 12vdc. I think I read that the ezb4 will only put out the same voltage as applied to the input side (12vdc). Thanks Chris
Here is what I need, taken directly from manufacturers instructions.
Input Signal Circuit Opto-coupler input with 440 Ohm resistance (5 to 15 mA input current), Logic Low is input pulled to 0.8 VDC or less, Logic High is input 4 VDC or higher Pulse Signal Motor steps on falling edge of pulse and minimum pulse width is 0.5 microseconds Direction Signal Needs to change at least 2 microseconds before a step pulse is sent Enable Signal Logic 1 will disable current to the motor (current is enabled with no hook-up or logic 0)
I will not be using the enable signal. Thanks Chris
Are you attempting to control stepper motors? Is that what a "chopper" motor is? If so, I would highly recommend using a stepper motor controller instead of the EZ-B natively. That way you can offload the processing to a cheap stepper motor controller, rather than use processing power on the EZ-B.
Yes, One stepper motor. The motor is being controlled by a stepper drive(aka chopper drive). The drive for this motor requires a step, and direction set of pulses (5vdc). I may be able to post the entire pdf later when home, if that helps. Thanks again. Chris
STP-DRV-4035
STEPPER DRIVE 3.5A 12-42VDC 2-PH BIPOLAR MICROSTEPPING
Description SureStep microstepping drive, 3.5A per phase, 2-phase bipolar PWM controlled current, 12-42 VDC powered, optically isolated digital inputs for Step, Direction, and Enable. 1/2, 1/5, 1/10, and 1/50 step modes, 0.4-3.5A/phase, idle current cutback, and test mode are all dipswitch selectable (no software required).
I cant seem to link manual so this is its description, it is found at automationdirect.com. I already own the unit from a different project. Just want to clarify it will work with my new ezb4. Thanks Chris
I would try it with the PWM - and if that works, you're golden. Newer stepper motor controllers do not require the processing of the main brain (i.e. ez-b v4). This is because the EZ-B v4 is doing a billion other things. For example, it is streaming your audio, video, pwm, servos, serial ports, i2c, web server, wifi, and TCP/IP Stack. Performing repetitive things, such as turning on and off stepper motor solenoids is not a great use of it's function. I would recommend trying your device with the EZ-B v4 PWM. If that does not work, then using a newer model stepper motor controller - one that has a popular (i2c/serial) communication interface and relieves the processing of the EZ-B v4.:)
