Ubtech Alpha 1 Bluetooth icon Ubtech Alpha 1 Bluetooth — Bluetooth control for UBTech Alpha1 servos via ARC: map Vx to servo IDs, enable servos, and integrate with ARC movement & LEDs. Try it →
India
Ez430 Chronos Question
Hey guys,
My ez430 chronos works alright with the chronos control center, but when i try to connect it to ARC , as soon as I click the start button, it goes back to stop immediately... There is no error message in the debug too.. So what am I suppose to do?
I still couldn't find a way out... Can anyone help me out pleaseeee.......
Select the port for your chrones. Make sure there is no other software using your chrones. Press start on ARC.:)
I take that back.... There is a bug with some computers on the chronos. I tried my laptop and it worked great. Then I went to use another laptop with it and every time I pressed Start it reverted back to Stop. I'll fix it now and have it ready for the next release:)
Thank you DJ... I'll be graciously awaiting for your next release....
Hey @DJ , I haven't made an attempt with ez430 chronos all these days. But recently when I tried to control the robot with the watch, it worked perfectly fine. I used four servos for each arm in my robot. I tried to control the servos in elbow and the fist of robot with y and x axis respectively instead of the head and it gave a whole good effect as if the robot is trying to follow my hand pattern just like as it is in Real Steel. I'm planning to add Vuzix 920vr so as to get a whole good feel.
