Sorry, we don't support Linux - I am unable to answer that question.
I think there is a windows emulator to run window programs on LINUX ,not shore it will work ,but ?
I'm also trying to get the ARC running on Linux. Did you try using the Wine tool?
Virtual machines have been known to cause problems, although it could work, it's just going to be given as the reason behind any problem encountered.
Wine is not a VM. It runs only 1 application at a time. VM is not a good choice, since it would require high end processors and more RAM
WINE is an emulator therefore a virtual machine, it's not native, it's not supported by EZ-Robots, it's not recommended by EZ-Robots. But feel free to try it and let us know how you get on...
