Resolved Resolved by edison2!
Errors With Attempting To Work With The Kit Using Vb2010.
I need help with the following errors. the Bluetooth device has assigned com 8 to the ez board.
Warning 1 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 2 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 3 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 4 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 5 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 6 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Speech, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" which has a higher version "4.0.0.0" than the version "3.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 7 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" which has a higher version "4.0.0.0" than the version "3.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 8 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" which has a higher version "4.0.0.0" than the version "3.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 9 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "3.5.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 10 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 11 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Security, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 12 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "Accessibility, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 13 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Runtime.Serialization.Formatters.Soap, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 14 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Deployment, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 15 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Data.SqlXml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 16 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "Microsoft.VisualC, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "10.0.0.0" than the version "8.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 17 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the framework assembly "System.Xaml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which could not be resolved in the currently targeted framework. ".NETFramework,Version=v3.5". To resolve this problem, either remove the reference "EZ_B" or retarget your application to a framework version which contains "System.Xaml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089". VB - Tutorial 01 - servo Move Warning 18 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Xml.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "3.5.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 19 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Data, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 20 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "UIAutomationProvider, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" which has a higher version "4.0.0.0" than the version "3.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 21 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "UIAutomationTypes, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" which has a higher version "4.0.0.0" than the version "3.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 22 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the framework assembly "System.Windows.Input.Manipulations, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which could not be resolved in the currently targeted framework. ".NETFramework,Version=v3.5". To resolve this problem, either remove the reference "EZ_B" or retarget your application to a framework version which contains "System.Windows.Input.Manipulations, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089". VB - Tutorial 01 - servo Move Warning 23 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the framework assembly "System.Numerics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which could not be resolved in the currently targeted framework. ".NETFramework,Version=v3.5". To resolve this problem, either remove the reference "EZ_B" or retarget your application to a framework version which contains "System.Numerics, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089". VB - Tutorial 01 - servo Move Warning 24 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Runtime.Serialization, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "3.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 25 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Transactions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 26 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.EnterpriseServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 27 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the framework assembly "System.Runtime.DurableInstancing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" which could not be resolved in the currently targeted framework. ".NETFramework,Version=v3.5". To resolve this problem, either remove the reference "EZ_B" or retarget your application to a framework version which contains "System.Runtime.DurableInstancing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35". VB - Tutorial 01 - servo Move Warning 28 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.DirectoryServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 29 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Runtime.Remoting, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 30 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 31 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "Microsoft.Build.Framework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "3.5.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 32 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the framework assembly "System.Runtime.Caching, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which could not be resolved in the currently targeted framework. ".NETFramework,Version=v3.5". To resolve this problem, either remove the reference "EZ_B" or retarget your application to a framework version which contains "System.Runtime.Caching, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a". VB - Tutorial 01 - servo Move Warning 33 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the framework assembly "System.Web.ApplicationServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" which could not be resolved in the currently targeted framework. ".NETFramework,Version=v3.5". To resolve this problem, either remove the reference "EZ_B" or retarget your application to a framework version which contains "System.Web.ApplicationServices, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35". VB - Tutorial 01 - servo Move Warning 34 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Web.Services, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 35 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the framework assembly "Microsoft.Build.Utilities.v4.0, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which could not be resolved in the currently targeted framework. ".NETFramework,Version=v3.5". To resolve this problem, either remove the reference "EZ_B" or retarget your application to a framework version which contains "Microsoft.Build.Utilities.v4.0, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a". VB - Tutorial 01 - servo Move Warning 36 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.DirectoryServices.Protocols, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 37 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 38 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the framework assembly "Microsoft.Build.Tasks.v4.0, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which could not be resolved in the currently targeted framework. ".NETFramework,Version=v3.5". To resolve this problem, either remove the reference "EZ_B" or retarget your application to a framework version which contains "Microsoft.Build.Tasks.v4.0, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a". VB - Tutorial 01 - servo Move Warning 39 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.ServiceProcess, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 40 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Web.RegularExpressions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 41 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Drawing.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 42 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Data.OracleClient, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 43 The primary reference "EZ_B" could not be resolved because it has an indirect dependency on the .NET Framework assembly "System.Configuration.Install, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" which has a higher version "4.0.0.0" than the version "2.0.0.0" in the current target framework. VB - Tutorial 01 - servo Move Warning 44 The designer cannot process the code at line 25:
Me.EzB_Connect1 = New EZ_B.EZB_Connect
The code within the method 'InitializeComponent' is generated by the designer and should not be manually modified. Please remove any changes and try opening the designer again. C:\Users\James Few\Downloads\EZ-B SDK Windows\EZ-SDK\VB\VB - Tutorial 01 - servo Move\Form1.Designer.vb 26 0 Error 45 Type 'EZ_B.EZB_Connect' is not defined. C:\Users\James Few\Downloads\EZ-B SDK Windows\EZ-SDK\VB\VB - Tutorial 01 - servo Move\Form1.Designer.vb 26 31 VB - Tutorial 01 - servo Move Error 46 Type 'EZ_B.EZB_Connect' is not defined. C:\Users\James Few\Downloads\EZ-B SDK Windows\EZ-SDK\VB\VB - Tutorial 01 - servo Move\Form1.Designer.vb 81 39 VB - Tutorial 01 - servo Move Error 47 'EZ_B' is not declared. It may be inaccessible due to its protection level. C:\Users\James Few\Downloads\EZ-B SDK Windows\EZ-SDK\VB\VB - Tutorial 01 - servo Move\Form1.vb 6 29 VB - Tutorial 01 - servo Move Error 48 'EZ_B' is not declared. It may be inaccessible due to its protection level. C:\Users\James Few\Downloads\EZ-B SDK Windows\EZ-SDK\VB\VB - Tutorial 01 - servo Move\Form1.vb 7 29 VB - Tutorial 01 - servo Move Error 49 'EZ_B' is not declared. It may be inaccessible due to its protection level. C:\Users\James Few\Downloads\EZ-B SDK Windows\EZ-SDK\VB\VB - Tutorial 01 - servo Move\Form1.vb 8 27 VB - Tutorial 01 - servo Move Error 50 'EZ_B' is not declared. It may be inaccessible due to its protection level. C:\Users\James Few\Downloads\EZ-B SDK Windows\EZ-SDK\VB\VB - Tutorial 01 - servo Move\Form1.vb 14 49 VB - Tutorial 01 - servo Move Error 51 'EZ_B' is not declared. It may be inaccessible due to its protection level. C:\Users\James Few\Downloads\EZ-B SDK Windows\EZ-SDK\VB\VB - Tutorial 01 - servo Move\Form1.vb 19 88 VB - Tutorial 01 - servo Move stress stress stress stress
Netherlands
What visual studio are you using? It doesn't seem like you imported the EZ-SDK DLL under 'Resources'.
Please read the included README.TXT file in the EZ-SDK
I am using Microsoft Visual Studio 2010 Ultimate (32/64-bit)and I did double-check to ensure the DLL were indeed imported. I think it would help if I had the example codes that the videos keep talking about. Possible to get a copy of the codes? I was hopeful to had a working robot for a upcoming AITP chapter meeting this Wednesday. I downgraded my system to windows 7 as it appears that windows 8 and ARC have issues.
All of the examples were in the the zip file you downloaded. You need to read the readme file. All your answers about getting started are in there.
There is no problem with Windows 8, although if you are running a pre release of 8.1 there may be an issue.
localize problem with Bluetooth driver under windows 8 pro. Still having issues getting automation on the robot's movement and getting the arms to move randomly. the i2c sensor acts like it may need to be calibrated has it reads the sold at 25"-255" when it is placed at 30" from the wall.
decided to go with a script base code but having problems with the range. it does one of two things goes forward and runs into things or spins in a circle going no where fast
Ecuador
Hey! the problem is that you have installed Net Framework 2.0.. you need to install the net framework 4... and if you still have problems you have to specify the version of the framework and the CPU target..
framework installed is showing 4.1. I need to downgrade?
