what's in EZ-Robot for Electrical Engineering students??
I think its only fun.... what you say?
Servo Speed
— Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved.
NASA uses EZ-Robot
We appear fun because that's our thing. I'm certain engineering students can have fun too
EZ-robot has more potential than anything else you'll come across. It's scalable. You can create your own controls, or use the ones we provide. There are thousands of features and unlimited potential.
Agreed
You can get on with all the great engineering and forget about the nasty C## Stuff . Unless thats your thing of course. In which case use the SDK and programm your brains out. Its all good.
You said it Steve_C. The potential is unlimited. Yes, most of us are playing with "toys", but what better way to learn. Then take that to the next level with a large scale robot that can really help you or others. It is a fantastic way to test out theories.
@DJ Sures : it asked not to under estimate Ez-Robot, it really a great thing you have done, It's great inspiration for robotics...... but my question was as an Electrical Engineering student, I dont think it will hep me, in my Semester Projects,.... Am I right???
@ahmad2370 i don't know what your semester project details are - but i can say it will help anyone. EZ-Robot does everything - and because it has C# built in, if it doesn't do it, then you make it do it
HI ahmad2370
Electrical Engineerings all about power distribution and control , right . An EG is a convayor system with a robot arm to pick an place , throw in a vision system to identify correct placement and conponent and you have a very good Semester Project.
All EZly done with a EZ_B
Steve_C .
The great thing about this system is it helps anyone new get started and then you can take it as far as you want to go. Limitless building and programming. If you have a project in mind then this system can go all the way. I have been building robots for years and this system lets me get more done much faster than anything I have used before. I will be buying more as I never stop building. Always have something new I want to do. I will be upgrading my full scale R2D2 with this system and my half scale C3PO. I am also working on a humanoid of my own design.
