EZ-B V3 Configuration icon EZ-B V3 Configuration — Manage EZ-B hardware settings: edit Bluetooth name and apply updates to restore altered configurations. Try it →
EZB Connections Controlcommand Support Query
I have a question regarding the EZB Connections robot skill in Synthiam ARC. Does this skill support the use of ControlCommand within scripts? I noticed there is no list of available ControlCommands under the Cheat Sheet section of the script tab. Would appreciate some guidance.
EZB Connection by Synthiam
EZB Connections by Synthiam
Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices.
Unfortunately, the connections skill is quite legacy and doesn't support control commands like the regular connection skill (at this time, continue reading...). However, there is an upcoming change to the connection skill, which allows adding as many ezb's as needed. This will operate similarly to the connections skill.
How many ezb connections would you require? This helps us understand use cases. Thanks!
I am using 6 ezb's at this moment.
