EDU Activity Editor icon EDU Activity Editor — Design, edit and export structured Blockly-based lessons, groups and hints for ARC Lite Portable; supports rich HTML, images, JSON import/export. Try it →
Russia
12AmP, 30A
Russia
12V, 30A
If you are refering to a hobbyist style Electronic Speed Controller (ESC), the answer is YES. Use the Modified servo Movement Panel.:)
*Note: you can press the EDIT button next to your post. That will allow you to edit rather than making new posts as corrections:)
