Analog output would be pwm. The answer is yes:)
you could see it that way I guess but in my mind that is a pure 0V and 5V line no increasing/decreasing sinusoidal wave just a variance in the pulse width, kind of more digital to me , but you da boss DJ.
Hehe it's as close as analog output as you'll get from a digital source:)
You can generate an analog out from the EZB PWM this is an example circuit there are lots of others. You just need a low pass filter which could be just a capacitor and a resistor click here
