What would you like the script to do?
measure side distance to the wall using a ping,i see one for hc-sr04 but need it for a pararallax ping one wire
Hey, Fred! Parallax has the scripts on the parallax sight.
that using basic stamp not EZB board
@RobotMaker, it would be the same as using the HC-SR04. You simply specify the ECHO and TRIGGER ports as the same since it's only one wire.
ok will try thanks DJ
@MOVIEMAKER MEL you looking to buy a EZ-ROBOT board
I am looking to aquire one at some point in the future. I was planning on trading stuff for it. Mel
