Set Digital icon Set Digital — Toggle a digital I/O port between TTL low (0V) and high (3.3V/5V) in ARC; select board and port, simple on/off control-signal only. Try it →
Can you provide more details?
Twitter
Hi edbot, Are you loading the correct app for the robot?
Yeah let's find out how we can get you up and running:D
thanks ,
I uploaded a video of the initscript startup on connection. ( I think?? Not sure if the video is here)
I have also uploaded my project to the cloud, so hopefully you can see what the problem is .
#5   — Edited
Hi Edbot,
I don't see the project or the video you mentioned. It's probably not you. There's a few gremlins on this new forum right now.
It's been my experience that running an int script when your project starts is a wonderful way to set servo speeds, servo min/max ranges, positions, set variables and tons of other needed things to make your project run.
Good luck and have fun.
Trouble with the site ..... I keep getting:    Error submitting the comment. Comment too short for submission. when I try to post but this is the issue with my InitScript
RE3D12_14_18.EZB
hopefully this helps to understand my issue
#7   — Edited
Well, that's one interesting robot. Kinda reminds me of Road Warrior. Very cool and imaginative. I love it!
I wish I could find your project you saved to the cloud. That could help me see what's going on with your script.
Looks like you have a wrong position command in your script or an improperly calibrated servo there.
Can you move the servo properly with a servo control in ARC. If it moves erratically like that when you use the slider in the control then you may have a bad pot in the servo.
I like your color scheme and angry temperament! Looks like a movie clip of an evil Inmoov trying to escape something.
That doesn't help your problem, I know.
