Command Duplicator icon Command Duplicator — Duplicate and synchronize commands from one master EZ-B to multiple slave EZ-Bs for simultaneous, mirrored robot actions. Try it →
Continuous Servo Movement
Hello,
I've recently finished creating my robot with the developer kit and everything is fantastic!
I'm just a little confused with the continuous servos, I've got one on each side of my robot for the wheels, however when I control it to move forward, I have one wheel moving forward and the other moving in reverse.
this is probably me being really stupid but how do I resolve this?
thank you:)
Hi @OscarBest,
You have a few options:
  1. You can physically take the servo off the robot, turn it 180 degrees and then place it back on the robot.
  2. If you are using a continuous rotation Movement Panel in ARC you can just swap the forward and Reverse values (instead or Forward = 180, Forward would be = 1, and vice versa for Reverse)
Hopefully that helps:)
