Hi, I'm working to customize JD with much longer arms. Is there a way NOT to have the arms fly out straight when you initially connect? Thanks
bmarkert1985
— Edited
Custom Movement Panel V2
— Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives
You can modify the init frame in the auto position. That’s the frame that initializes the servos
here a pic .delete calibrate position.and put in the stand position.
Thanks This was very helpful
bmarkert1985
a picture is always the best thing.
