User Defined Function Example icon User Defined Function Example — Add custom EZ-Script functions in C# or JS; intercept unknown calls, parse parameters and return values via AdditionalFunctionEvent. Try it →
Since the servo uses PWM for control, it "may" work directly with the ezb4 (from the servo stats 280 degree / 0.9us ~ 2.1us PWM) ... However having a 280deg rotation angle you might be able to control it much better (greater rotation angle) using an SSC-32 board....
Thank you Richard, I will look at using the ssc-32 with the ezb.
