Singapore
Color Tracking In Sdk C#
Hi everyone,
I am exploring the Tutorial 11 example for Color Vision Tracking. I needed help understanding the codes and I was looking at the forum for any discussions. I realised that most of the discussions are regarding the AR Drone. What I want to ask is, is this tutorial applicable to the JD Humanoid robot?
Thanks everyone!
Simple answer is yes.
You could have the vision module affect the movement panel. so if the Movement Panel is for a drone it will affect the drone but if you use other Movement Panel it will work too.
I have used it for my drone as well as for a tracked vehicle.
You are just not going to get he up and down movement.
