hello
how can I connect to the Wii remote using the code I want to switch it on or connect to the Wii remote using the code because I want to put some statements before it starts connecting how can I do that?
Lynxmotion Smart Servos
— Compact Lynxmotion Smart Servos with position feedback, safety features and UART TX/RX for Arduino/EZ-B v4; scriptable temp, load, load-dir and ping.
hello
The wiimote is a manual connection process as documented in the learn section. This is a limitation to the device. The help for it can be found here: https://synthiam.com/Tutorials/Help.aspx?id=154
so for example, if want firstly the robot recognize my face after that the Wii remote start working is it possible to do it using script?
and if I want both hands to work together I need to remotes?
as my friend explain to you our project which is IPIA system yesterday one of the games is the child should dance using the Wii remote the robot should imitate him by moving the robot hands.
Thank you
Yes - in the Camera Tracking script, add a ControlCommand() that unpauses the WiiMote. Check The Robot Program for examples on how to do things like that. The robot program episodes teach you the basics so you can build off. It's pretty fun
