DHT11 Temp & Humidity Sensor icon DHT11 Temp & Humidity Sensor — Read DHT11 temperature and humidity on Arduino (signal pin 4) using EZ-Genuino_DTH11_Uno firmware; exposes $Temp and $Humid variables. Try it →
Resolved Resolved by Jeremie!
Clarification Of Ev-Bv4 Digital Input And Output Levels
Hello,
I have read about the digital inputs and outputs and have some questions to clarify my understanding of them:
Am I correct in assuming that the digital I/O pins can be set as inputs and read as either 0V(logic 0) or +5V(logic 1) via EZ-Script. Also can they be set as outputs and the output level set to 0V (logic 0) or +5V (logic 1) via EZ-Script?
The Data Sheet for the EZ-Bv4 suggests that the high level for a TTL output is 3.3V and doesn't show what the low level is. I am assuming it would be 0V. According to the data sheet a logic high (1) would be 3.3V and it doesn't really show what logic 0 is (should be 0V)? Seems output logic 1 level should be 5v?
What is the digital I/O power pin used for and what is its value. Is this used to power the servos only. I have a Lipo Battery powering my adventure robot so I am assuming the digital I/O power pin is at about 7.4 volts?
Thanks much for the clarifications on the I/O pins and how to set and read them via EZ-Script.....Rick B.
Why is the high level for outputting to a port only 3.3V and when inputing a high level is 5V? (5V=1, 0V=1)?
You're welcome Rick:)
It didn't work:) But i have no doubt that you will figure it out
Hello DJ,
That is odd as I received a thank you from Jeremie. He must have been on the forum at the dame time I made the post......Rick
Hello,
Had to go my laptop to resolve the issue. Still looking into why this doesn't work on my Samsung Galaxy S4. Will post when I have the answer, but for now I have a work around....Rick B.
