Ubtech Alpha 1 Bluetooth icon Ubtech Alpha 1 Bluetooth — Bluetooth control for UBTech Alpha1 servos via ARC: map Vx to servo IDs, enable servos, and integrate with ARC movement & LEDs. Try it →
Can't Connect To Ez_b Board By C# Tutorial 11
Can't Connect To Ez_B Board By C# Tutorial 11
Hello everyone. There is one question I hope someone could help me. I have connected to the ezbv4 board with my computer. And I run the "tutorial 1 - Modified Servo" successful. I can control the servos.
But when I run the "tutorial 11 - color vision tracking" . It was successful to build, and success to run the program. But when I click the "connect" button, there is the problem, It stayed in the "connecting" state. Like this:
And the comboBox could not show the camera device. So I can't open the camera.
PS: I run EZ_Builder with the ez_b v4 board. It is good for everything. I can connect the board and I can use the camera.
PPS: My environment win 7 Visual Studio 2013 .net framework 4.5 or 4.5.1
Please help me. Thanks!
I have solved the problem. I putted all dlls into the debug folder. Then it works. But the "connect" button still on "connecting" state. So pls help me :P
  1. Connect to your EZ-B v4 over WiFi. There are connection videos in the LEARN section.
  2. Select your video device from the drop down
It's a very simple project - view the code to see. Connecting to the EZ-B v4 is only necessary for servo tracking. If you wish to experiment with vision tracking in general, simply select the video device from the drop down.
