Midi Control icon Midi Control — MIDI I/O for ARC: send/receive notes, run per-note scripts, control PC or external instruments, with panic to stop stuck notes. Try it →
Resolved Resolved by Herr Ball!
Can You Cut Off The my Battery Is Low Alarm On Ezb4?
Can You Cut Off The My Battery Is Low Alarm On Ezb4?
I would like to cut off the alarm. I am using the ezb4 on +5volts. I am going in with +12v. I want the bus to be +5v so it doesn't blow the IR and Ultrasound. So, I am having a +12v to ezb, also a 7.5v and also a +5volts. I am running off of a PowerPS solutions which is a lead-acid batter, not Lipo.
thanks in advance! :-)
Be careful when shutting this off?
