Camera turns on fine, but doesn't turn off. I hold it down for two seconds and it turns on. But, I cannot get it to turn off unless the battery is dead. Is this normal?
MovieMaker
— Edited
Tic Tac Toe
— Play Tic Tac Toe with your ARC robot: configurable turn, win and draw scripts, cheat commands and optional speech-recognition control.
this cameras are strange.... you have to hold the button of the camera until the camera led turn of.... maybe 8 or 15 seconds...
I tried for a minute and a half. No Soap.
mmmm maybe your camera has a problem.... i can suggest you one thing...
open your camera... remove the battery.... and adapt your camera to use the power of Ez-Board... here you have how!
good luck!
Try holding a few sec, let go and hold longer the 2nd time. I got rid of the battery and wired directly to EZ-B power with two diodes to drop voltage to 3.4v and signal wire to turn on using ARC, works great, no point in using separate battery when you installed inside the robot without ever having access to charging it or turning it on/off.
@Louis T but is not necesary to use diodes.... the camera uses 5v.... I have been using my camera with out diodes and the camera works perfectly---
It uses 1s lipo 3.7v and also after watching DJ video he mentioned CMOS camera don't like 5Vso i didn't want to fry it. I don't mind doing this. That's good if it works for you. How long have you been using it like this?
Wouldn't that void the warranty even though I am a technician?
@Louis T Dj uses the power of the Ez-Board.. and the Ez_board provides 5V....
and the last week in a fair sciencie at mi high school I used the camera with Ez-Board for 6 hours per day for 3 days continuos
