Talk Servo V2 icon Talk Servo V2 — Animate servos to simulate jaw/mouth with ARC text-to-speech; configurable vowel/consonant timing, start sync, multi-servo control, pause/stop. Try it →
ptp
yup , i still need ur help . I've run ur code but it gave me the following error in the image ,
for that i asked u to control the camera from my windows form . for example i try to put ur code in a button in my form but unfortunately , it didn't work
Are you sure that you're creating a plugin? Or a standalone application?
Also, do not use ptp's code. Use the tutorial that i posted.
In the tutorial, to draw on a Panel, for example...
void Camera_OnNewFrame() {
  if (_cameraControl == null)
    return;
  using (Graphics pnlG = panel2.CreateGraphics())
    pnlG.DrawImage(_cameraControl.Camera.GetOutputBitmap.ToManagedImage(false), 0, 0, panel2.Width, panel2.Height);
DJ. He is not building an ARC plugin. Needs SDK instructions (I would provide but answering from phone).
If you're not building a plugin, then read the README.TXT that is included in the SDK. You're not following the instructions. All files from the SDK package must be copied into your output folder. Read the instructions.
If you are making a plugin, then read the tutorial and use the code i presented.
Attention to:
DJ wrote:
Platform target: must be x86 (32 bits)
Some dlls are needed in the application folder you have two options:
  1. copy the dlls "packages/EZ_B.dll.2015.05.20.00" to the application folder i.e. (bin/debug or bin/release)
  2. add application references to the missing dlls: e.g. VS>Project>Add Existing Item>(look for the missing DLL)>ADD VS>Project>dll properties>"Copy to Output Directory" Change to "Copy if newer"
personally i like the option 2, you are aware of the dlls needed, but the safest option is the 1).
#16
thanks ptp for your help ,I appreciate you effort _
