Brookstone Rover
Hi. I have a brookstone rover v1 and i can`t get ezrobot to conect to it. i get this message......EZB 0: EZB 1: EZB 2: EZB 3: EZB 4: 13/03/2015 07:31 - TCP Server stopped 13/03/2015 07:31 - TCP Server stopped 13/03/2015 07:31 - TCP Server stopped 13/03/2015 07:31 - TCP Server stopped 13/03/2015 07:31 - TCP Server stopped 13/03/2015 07:32 - TCP Server stopped 13/03/2015 07:32 - TCP Server stopped 13/03/2015 07:32 - TCP Server stopped 13/03/2015 07:32 - TCP Server stopped 13/03/2015 07:32 - TCP Server stopped 13/03/2015 07:32 - System.Exception: Brookstone Rover v2 is not currently supported. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:32 - System.Exception: Brookstone Rover v2 is not currently supported. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:32 - System.Exception: Brookstone Rover v2 is not currently supported. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:32 - System.IndexOutOfRangeException: Index was outside the bounds of the array. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:33 - Attempting connection on 192.168.1.1:23 13/03/2015 07:33 - Connection Failed: System.Net.Sockets.SocketException (0x80004005): No connection could be made because the target machine actively refused it 192.168.1.1:23 at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult) at System.Net.Sockets.TcpClient.EndConnect(IAsyncResult asyncResult) at EZ_B.EZB.Connect(String hostname, Int32 baudRate) 13/03/2015 07:33 - Disconnected 13/03/2015 07:33 - System.IndexOutOfRangeException: Index was outside the bounds of the array. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:33 - System.IndexOutOfRangeException: Index was outside the bounds of the array. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:33 - System.IndexOutOfRangeException: Index was outside the bounds of the array. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:35 - System.IndexOutOfRangeException: Index was outside the bounds of the array. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:35 - System.IndexOutOfRangeException: Index was outside the bounds of the array. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:35 - System.IndexOutOfRangeException: Index was outside the bounds of the array. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:35 - System.Exception: Brookstone Rover v2 is not currently supported. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:36 - System.IndexOutOfRangeException: Index was outside the bounds of the array. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:37 - System.IndexOutOfRangeException: Index was outside the bounds of the array. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:37 - System.IndexOutOfRangeException: Index was outside the bounds of the array. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:38 - System.Net.Sockets.SocketException (0x80004005): An established connection was aborted by the software in your host machine 192.168.1.100:80 at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:38 - System.Net.Sockets.SocketException (0x80004005): A socket operation was attempted to an unreachable network 192.168.1.100:80 at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:39 - System.IndexOutOfRangeException: Index was outside the bounds of the array. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:39 - System.Net.Sockets.SocketException (0x80004005): A socket operation was attempted to an unreachable network 192.168.1.100:80 at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:42 - System.IndexOutOfRangeException: Index was outside the bounds of the array. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:42 - System.Net.Sockets.SocketException (0x80004005): A socket operation was attempted to an unreachable network 192.168.1.100:80 at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:44 - System.IndexOutOfRangeException: Index was outside the bounds of the array. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:44 - System.Net.Sockets.SocketException (0x80004005): A socket operation was attempted to an unreachable host 192.168.1.100:80 at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:44 - System.Net.Sockets.SocketException (0x80004005): A socket operation was attempted to an unreachable network 192.168.1.100:80 at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port) at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:44 - System.IndexOutOfRangeException: Index was outside the bounds of the array. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:44 - System.IndexOutOfRangeException: Index was outside the bounds of the array. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:44 - System.IndexOutOfRangeException: Index was outside the bounds of the array. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs ) 13/03/2015 07:44 - System.IndexOutOfRangeException: Index was outside the bounds of the array. at EZ_B.BrookstoneRover.() at EZ_B.BrookstoneRover.Connect(RoverVersionEnum version) at ? .(Object , EventArgs )
help as i don`t understand it. thank you Simon
Hi. my pc is windows 7 pro, download the new ez-robot software, new battureys in rover, blue light flashes,orange light on. i followed your video on an other pc to do every thing to conect, my pc conected but nothing else.
thank you simon
Brookstone Rover v1 and v2 support is temporarily not working. We have been working to get in contact with brookstone to obtain detailed protocol information.
Hi. thank you for the help,thought it was me doing something wrong. i was not thinking i was going to get an answer that fast as its early in moroning here and didn`t know if you are a wake as different time zones,
thank you very much Simon
@Simon, you'll find you get very fast answers regardless of time. DJ has a sleep pattern as screwed up as mine so is generally around most of the time as am I. And those rare times either DJ or myself are not about there is someone else around who will answer.:)
I am not going to turn into one of those "use the search engine" people every time someone asks a question that has already been answered, but I am going to point out that searching the forum for Brookstone Rover has 112 hits, the first 50 or so of which answer this question.....
Hi. Sorry all i did not use seach engine as i am new to this and if it was mechanical i would have no problum i would be able to repair or make a new part. But i am still learning about computers as need it to do my hobby (quadcopters).
  Thany you for your help.......Simon
No worries. Like I said, not going to be one of those people who points it out all the time. Just mentioned because this one comes up a lot....
