EZB Connect By Name icon EZB Connect By Name — Discover EZB WiFi controllers by name, auto-bind connections, avoid IP management; live discovery and multi-EZB support for ARC. Try it →
Bing Speech Recognition Control Moves To Desktop 2 And Cant Be Moved
My Bing speech recognition control sometimes moves to the second desktop and I can not move it from there. I am right clicking on the window for the option but it does not appear once the control is on the second desktop. I can move all other controls as normal.
Is this a bug? I believe it happened with the last update but not sure.
Plugins add to the current viewable desktop. However, when project is saved, plugins will always load to desktop 1.
Except for the bing speech recognition plugin. For me:) It is now on the second desktop of all my projects. Saved them all many times and they all open with this plugin on desktop 2
Any more thoughts here. This is getting annoying. Can anyone else comment if this is happening to them?
I also notice that the API.AI plugin cannot be moved once it is placed on Desktop 2
EZR and plugins are both updated to latest version
I can confirm that when a plugin is placed on the second desktop, and then you right mouse click the plugin, the option to move the plugin to the other desktop doesn't appear. On controls, the option does appear. I have tried multiple plugins and it appears to be all plugins.
Just wanted to let you know that it isn't your machine or install or anything like that Perry. Sorry it took me so long to test out. I haven't had ARC open long enough to test it out until tonight.
Thanks for checking. Driving me crazy. The Bing Speech plugin 'automoves' to my second desktop on all my projects. Frustrating.
One more piece of information...
When I saved and closed the project after placing a plugin on Desktop 2, all of my plugins moved to desktop 2 when reopening the project.
Forgot to add David. Thanks for the work around. I can reset from the Controls menu.
So probably a bug.
Okay, a little more testing... I removed the plugins and then re-added them to the first window and then saved the project, closed the project, and reopened the project. At that point, all of the plugins were on the first desktop.
Anyway, hopefully that works out for you Perry and gives DJ some more information to check to see if it is a bug or meant to function this way. Maybe it is an issue with where the first plugin is placed or something. IDK but, this is what I discovered.
