Servo Script icon Servo Script — Bind scripts to servo moves (V1-V99); triggers on position/speed/accel changes and provides ports, positions and speeds arrays for custom control. Try it →
Best way to attach onboard computer to EZB V4
Best Way To Attach Onboard Computer To EZB V4
All the upgrades and changes this past year or so to EZ Robot and Synthiam's ARC software (Used to be ARC) has left me behind a lot. Other life demands has kept me from experimenting with my robot and learning all the new ways to use ARC. Granted the EZB hasn't changed but ARC is a whole new animal.
Anyway, from the start of my adventures with this robot platform back in the EZB V3 days I've always wanted to mount an onboard computer on my robot. A few things has kept me from doing this:
*Along with the above mentioned events the mini computers didn't seem quite mature enough to jump into it.  *I really wanted voice recognition. With the computer being on the robot, the noises the robot make really mess up the VR. (I'm using a Bluetooth headset now so that shouldn't be an issue anymore). *I really haven't been able to wrap my head around the best way to hook up all 4 EZB's I have in my robot to one onboard PC if mounted inside my robot. Sections of my robot twist, bob and bend and I want to keep the cables going through these joints to a minimum. As much as I would like a direct connection between the EZB and the onboard PC I think I'd have to have both options, Wifi connected and direct connection.  *I really can't find information on this forum on how to attach a EZB V4 directly to a PC. Maybe I totally missed it. I do see discussions on connecting through USB but where to attach to the EZB? How to configure the PC and ARC?
To this point I've been discussing my personal full sized B9 Robot from the TV show Lost In Space. I still want to mount a PC onboard it but I'm currently building another one for a fan up in NH, USA. I'm at the point of deciding if I want to have the PC mounted in the robot with direct connection or outside and connect with Wifi. This Robot will only have two EZB's. These EZB's are already here for me to use and I'd like to use them instead of converting an Arduino. I guess I could do that but I'll be needing ADC ports and Digital ports. I have zero experience with Arduino or this conversion process.
I'm really leaning towards using an Up Board as the onboard PC but would maybe need Wifi connectivity to reach remote EZB's mounted in hard to reach areas of the robot.
I guess I'm asking for suggestions on: *Links on this forum where I can find attaching a PC directly to the EZB or other boards so I don't have to ask too many questions.  *If I should sideline these EZB's and use something else I can flash and convert that would work better for my application? *How easy and clear it it to use a remote client to log into the onboard computer to manage it from outside the robot? What is the best software to use now-a-days for this? I guess this means I'd need two PC's? the Up Board mounted on the robot and the one I'm using to log into it to work with ARC and maintain.  *How the heck do I connect a PC directly to an EZB or another board if I decide to use something else? *Can I have one EZB attached directly to the PC and one EZB connected to it through Wifi at the same time and controlled by the same ARC project?
Thanks for reading this long request and thanks for the help in advance. Any suggestions are welcomed.
Working on this one.   PTP made me a cable because he had the right tool.  It connects the EZ-B camera port to a USB port on the computer.  I'll find the thread with the instructions and post back here.
Since you already have the EZ-B's, probably not much point in switching.  If you didn't, then Arduino are a lot less expensive.
Super easy.  I used to recommend TeamViewer, but they have a nasty habit of thinking you are using it for commercial use and trying to sell you a license.  I am now using Anydesk.  note, those both allow access through the internet.  If you just want something on your own network, then VNC is a great free choice (also works over the internet, but requires a lot more knowledge to set up securely).  Chrome Remote desktop might be another option.  I haven't played with it lately.  What you don't want to use is Windows Remote Desktop.  It actually logs you in as a separate session, and on home edition, logs out the local user (which would be running ARC) so not a good robot control option (at least that is how it worked in Windows 7.   I have been using other options for so long, I haven't even tried it on Windows 10 yet, so if someone has better info, please correct me).
Depends on the board.  With EZB, see answer 1 above.
Yes!  :D
Thanks Alan! Wonderful help. I'll look for that link also later if you can't get to it.
I am building a new robot with a EZB-4 and Iotiny connected with wifi form my laptop
EzAng
#7   — Edited
Ya their manual isn’t very clear. It’s like this. Connect your tx to the rx of the ezb. And the rx to the tx
Thanks. Glad I checked. The labelling on the EZB is a much clearer guide.
