Myo Gesture Armband icon Myo Gesture Armband — Map Myo armband gestures and accelerometer to servos and ARC scripts for arm-mimic control; supports multiple armbands. Try it →
Automated Ez-room
Automated Ez-Room
hey ARC s! I was looking to automate my room using the ez-board. I planned on being able to turn things on and off, weather reports, checking rss feeds, etc. I have a desktop computer in my room that i never use but would be perfect to run the software 24/7. To control outlet power/power strip for each individual plug Im assuming i would need some type of relay in line with the plug? The programming would be the easy part. However Im not sure what i would need so that the digital port on the board can interact with the plugs. Does anyone have a safe and reliable way of going about controlling outlet plugs so i don't electrocute myself or burn my house down?
I feel like I remember someone doing this a long time ago with their workshop. But i was unable to find the thread again. Any help or suggestions would be great! I just saw the new iron man/stark industries piece that disneyland put in the innovations building and want to build my own Jarvis-like system using a dedicated ez-board and desktop:D
Wow thank you guys so much for the help! I am learning a lot about what is required to do this the right way. I only want to do this once if you know what i mean. haha I obviously have a lot of research to do
Tameion: yes the original project i remember seeing was yours! thank you for the link
New Zealand
Rich... you are a man in demand.... Can you answer a couple of questions?
Q1: What were the, " RF outlets and modules (very cheap), an RF tranceiver," you mentioned? Do you have a web address?
You have already introduced me to EventGhost and it is doing some of the leg work for me too...
But I am loving calling Exec directly from ARC... especially to open a web page or play a music file at a set time.
Q2: Can you give me an example of the "very basic PHP code to broadcast over the network" and the HTTPGet function to operate anything connected to the system." that you used....
It would save me a lot of time ...
I use HomeEasy outlets, they are just the bog standard, cheap, RF socket outlets. From what I have found out many unbranded ones are the same.
It uses a USB RF Transceiver from RFXCom. The RFXtrx433
Also, it picks up OWL energy meters and a bunch more so it can log electric usage.
Temperature, humidity, external temp etc. all work differently through some custom python scripts, web pages, but requires linux so another PC. It's specific to my controls so will be useless here so wont post the full details yet.
The php code (never looked at tidying it up)
// Send event to EventGhost
// Usage - SendEvent.php?event=MyEvent&REFERER=next.html
function sendMsg($args)
    $fp = fsockopen($args["host"],$args["port"], $errno, $errstr, 10);
    if (!$fp)
    { //Something didn't work....
        echo "ERROR: $errno - $errstr\n";
        return FALSE;
    } else {
        fputs($fp, "quintessence\n\r");
        $cookie = fgets($fp, 400);
        $cookie = trim($cookie);
        $token = $cookie . ":" . $args["password"];
        $digest = md5($token);
        $digest = $digest . "\n";
        fputs($fp, $digest );
        $res = fgets($fp, 400);
        if ( trim($res) != "accept" )
             fclose($fp);
             return FALSE;
        if (isset($args['payload']))
            if (is_array($args['payload']))
                foreach($args['payload'] as $key => $value)
                    fputs($fp, "payload " . $value . "\n");
            }else
                if ( $args["payload"] <> "" )
                    fputs($fp, "payload ".$args["payload"]."\n");
        fputs($fp, $args["eventstring"]."\n");
        fputs($fp, "close\n");
        fclose($fp);
        return TRUE;
if (isset($_GET))
    if(isset($_GET['host']))
        $args['host'] = urldecode($_GET['host']);
    else
        $args['host'] = '192.168.0.100';
    $args['port'] = 8083;
    $args['password'] = '';
    $args['eventstring'] =  urldecode($_GET['event']);
    foreach($_GET as $key => $value)
        if(strcasecmp(substr($key, 0, 3), 'pld') == 0)
            $args['payload'][] = urldecode($value);
    sendMsg($args);
    if(!isset($_GET['REFERER']))
        $_GET['REFERER'] = "control.html";
    header("Location: https://".$_SERVER['HTTP_HOST';]
           . dirname($_SERVER['PHP_SELF'])
           ."/".$_GET["REFERER"]);
REFERER is the page that should be displayed after the link Hopefully the forum formatting hasn't done much damage to the above.
Then just httpget("SendEvent.php?event=MyEvent&REFERER=next.html") and event is broadcast to EG.
Voice controls are done through VoxCommando however ARC could take it's place easily (mine is just all set up now so I haven't moved it over)
do you guys think that this relay could get the job done for each outlet?
relay
New Zealand
They look as good as any... Just makesure they are optically isolated and you follow best practice if working with mains voltages...
Ie. Check, recheck and then check again. And find a sparkie to check it one last time for you.
Anything I am doing at the moment has two relays turning on the device power... see pic.
This way I have to turn one off and the other on even before the device receives power.... A bit old school but I feel safer... as well as that if the EZRobot pins high or all pins low for some reason my project will not power up by mistake.
I tend not to mod the actual mains device and only mod tthe multi board it plugs into... maintaining device integrity.
Most importantly... keep safe!
#15
Good advice. And by not modifying the mains equipment you don't invalidate the warranty either:)
#16
hey rich (side note) Im really interested in Jarvis. have you created a showcase project? im really interested.
Back to the automated room topic.
