TCP Clients icon TCP Clients — Monitor incoming TCP Server connections when TCP Server is enabled under Connection > Config; view and track live connections. Try it →
France
Autoconnect Script, With Virtualrobot (And Digital)
Hi, Just to report a strange behavior with VirtualRobot in ARC:
When I add a Digital (Input or Outpout) to the VirtualRobot, then the autoconnect script (ControlCommand("Connection", Connect0)) don't work anymore and connection failed, without any error message. manual connection in the "Connection" window is OK.
I have tested it directly in the ARC Example: "Autoconnect"
  • No Virtual Robot window => ok
  • Virtual Robot window empty => ok
  • Virtual Robot window with a servo added => ok
  • Virtual Robot window with a Digital added => no connection with the Connect script
It's not really a big issue, but it took me some time to find out the problem in my project... so, if it happens for others, maybe it can help:)
