Resolved Resolved by Athena!
Arduino_v11 Symmetric PWM Steering
Arduino_V11 Symmetric PWM Steering
Thank you for the Arduino sketch and the ARC scripts.
I'm using the Arduino sketch (Arduino_v10) as the robot controller (acting as the EZB) connected to ARC (serial). The current problem with Arduino_v10 is that it does not adjust left and right motor PWM symmetrically: only one motor's PWM decays in relation to the bearing-difference change. Can you rewrite Arduino_v10 so the right and left motor PWM are adjusted equally when the bearing difference changes? Please call the revised sketch Arduino_v11.
Thanks, Jack
// Arduino_v10
#include <AccelStepper.h>
#include <MultiStepper.h>
#include <math.h>
// Protocol
static const uint8_t UART_HEADER = 0xA5; // ARC -> Arduino
static const uint8_t CMD_STOP_MOTORS    = 0x01;
static const uint8_t CMD_ACTUAL_BEARING = 0x03;
static const uint8_t CMD_RIGHT_PIVOT    = 0x04;
static const uint8_t CMD_LEFT_PIVOT     = 0x05;
static const uint8_t CMD_WAYPOINT_DATA  = 0x06;
// Arduino -> ARC
static const uint8_t RSP_NAV_ACK         = 0x10;
static const uint8_t RSP_TOTAL_STEPS      = 0x11;
static const uint8_t RSP_DESIRED_BEARING  = 0x12;
static const uint8_t RSP_OBS_SCAN_REQUEST = 0x13;
static const uint8_t MAX_PAYLOAD = 32;
// Motor setup
AccelStepper LeftFrontWheel(AccelStepper::DRIVER, 3, 6);
AccelStepper LeftBackWheel(AccelStepper::DRIVER, 2, 5);
AccelStepper RightFrontWheel(AccelStepper::DRIVER, 12, 13);
AccelStepper RightBackWheel(AccelStepper::DRIVER, 4, 7);
MultiStepper multiStepper;
// Parser
enum ParserState { WAIT_HEADER, WAIT_CMD, WAIT_LEN, WAIT_PAYLOAD, WAIT_CHECKSUM };
ParserState parserState = WAIT_HEADER;
uint8_t currentCmd = 0;
uint8_t expectedLen = 0;
uint8_t payloadIndex = 0;
uint8_t payload[MAX_PAYLOAD];
uint8_t runningChecksum = 0;
// Navigation state
bool navRunning = false;
uint32_t totalStepsTaken = 0;
uint32_t combinedStepsDesired = 0;
uint32_t pathTotalDistance = 0;
int32_t oppositeDistance = 0;
uint32_t nextScanStep = 0;
uint32_t scanIntervalSteps = 3056;
uint8_t bearingAlignment = 0;
uint8_t trackDir = 0;
uint16_t actualBearing100 = 9000;
uint16_t desiredBearing100 = 9000;
uint16_t lastSentDesiredBearing100 = 0xFFFF;
int16_t bearingDiffTarget = 0;
int16_t bearingDiffRamped = 0;
uint16_t currentSpeed = 0;
uint16_t normalSpeed = 600;
// Forward ramp / smoothing
uint16_t rampedSpeed = 0;
static const uint16_t MIN_FORWARD_SPEED = 60;     // start moving gently
static const uint16_t SPEED_RAMP_STEP = 2;        // speed increase per update
static const uint16_t SPEED_DECAY_STEP = 2;       // speed decrease per update
static const uint16_t MAX_BEARING_SPEED_ADJUST = 180; // clamp steering effect
static const int16_t  BEARING_DEADBAND = 3;       // ignore tiny bearing error
static const int16_t  BEARING_UPDATE_SMOOTH = 1;  // ramp bearing error slowly
// Pivot state
enum PivotMode { PIVOT_NONE, PIVOT_RIGHT, PIVOT_LEFT };
PivotMode pivotMode = PIVOT_NONE;
uint32_t pivotStepsDesired = 0;
uint32_t pivotStepsTaken = 0;
long pivotStartLF = 0;
long pivotStartLB = 0;
long pivotStartRF = 0;
long pivotStartRB = 0;
static const uint16_t PIVOT_SPEED = 600;
// Helpers
uint16_t readUInt16LE(const uint8_t* data) {
  return (uint16_t)data[0] | ((uint16_t)data[1] << 8);
uint32_t readUInt32LE(const uint8_t* data) {
  return (uint32_t)data[0] |
         ((uint32_t)data[1] << 8) |
         ((uint32_t)data[2] << 16) |
         ((uint32_t)data[3] << 24);
uint32_t abs32(long v) {
  return (v < 0) ? (uint32_t)(-v) : (uint32_t)v;
void sendPacket(uint8_t cmd, const uint8_t* data, uint8_t len) {
  uint8_t checksum = cmd ^ len;
  Serial3.write(UART_HEADER);
  Serial3.write(cmd);
  Serial3.write(len);
  for (uint8_t i = 0; i < len; i++) {
    Serial3.write(data[i]);
    checksum ^= data[i];
  Serial3.write(checksum);
void sendCmdOnly(uint8_t cmd) {
  sendPacket(cmd, nullptr, 0);
void sendTotalSteps(uint32_t steps) {
  uint8_t tmp[4];
  tmp[0] = (uint8_t)(steps & 0xFF);
  tmp[1] = (uint8_t)((steps >> 8) & 0xFF);
  tmp[2] = (uint8_t)((steps >> 16) & 0xFF);
  tmp[3] = (uint8_t)((steps >> 24) & 0xFF);
  sendPacket(RSP_TOTAL_STEPS, tmp, 4);
  Serial.print(F("TX: TOTAL STEPS = "));
  Serial.println(steps);
void sendDesiredBearing(uint16_t bearing100) {
  uint8_t tmp[2];
  tmp[0] = (uint8_t)(bearing100 & 0xFF);
  tmp[1] = (uint8_t)((bearing100 >> 8) & 0xFF);
  sendPacket(RSP_DESIRED_BEARING, tmp, 2);
  lastSentDesiredBearing100 = bearing100;
  Serial.print(F("TX: DESIRED BEARING x100 = "));
  Serial.println(bearing100);
void sendObstacleScanRequest() {
  sendCmdOnly(RSP_OBS_SCAN_REQUEST);
  Serial.println(F("TX: OBSTACLE SCAN REQUEST"));
void clearIncomingUart() {
  while (Serial3.available() > 0) {
    Serial3.read();
void resetStepperPositions() {
  LeftFrontWheel.setCurrentPosition(0);
  LeftBackWheel.setCurrentPosition(0);
  RightFrontWheel.setCurrentPosition(0);
  RightBackWheel.setCurrentPosition(0);
void resetPivotState() {
  pivotStartLF = 0;
  pivotStartLB = 0;
  pivotStartRF = 0;
  pivotStartRB = 0;
uint32_t getAverageAbsStepperPosition() {
  uint32_t a = (uint32_t)labs(LeftFrontWheel.currentPosition());
  uint32_t b = (uint32_t)labs(LeftBackWheel.currentPosition());
  uint32_t c = (uint32_t)labs(RightFrontWheel.currentPosition());
  uint32_t d = (uint32_t)labs(RightBackWheel.currentPosition());
  return (a + b + c + d) / 4;
void setAllMotorSpeeds(int leftSpeed, int rightSpeed) {
  leftSpeed = constrain(leftSpeed, -2000, 2000);
  rightSpeed = constrain(rightSpeed, -2000, 2000);
  LeftFrontWheel.setSpeed(leftSpeed);
  LeftBackWheel.setSpeed(leftSpeed);
  RightFrontWheel.setSpeed(rightSpeed);
  RightBackWheel.setSpeed(rightSpeed);
void stopMotors() {
  LeftFrontWheel.stop();
  LeftBackWheel.stop();
  RightFrontWheel.stop();
  RightBackWheel.stop();
  LeftFrontWheel.setSpeed(0);
  LeftBackWheel.setSpeed(0);
  RightFrontWheel.setSpeed(0);
  RightBackWheel.setSpeed(0);
  Serial.println(F("Action: stopMotors()"));
void finishPivot() {
  stopMotors();
  clearIncomingUart();
  resetStepperPositions();
  resetPivotState();
  Serial.println(F("Pivot complete and reset"));
void resetNavigationState() {
  nextScanStep = scanIntervalSteps;
  currentSpeed = 0;
  rampedSpeed = 0;
  navRunning = false;
  Serial.println(F("Navigation state reset"));
void beginForwardNavigation() {
  navRunning = true;
  currentSpeed = 0;
  rampedSpeed = 0;
  Serial.println(F("Navigation started"));
void beginPivot(PivotMode mode, uint32_t steps) {
  if (steps == 0) {
    Serial.println(F("Pivot ignored: steps = 0"));
    return;
  pivotMode = mode;
  pivotStepsDesired = steps;
  pivotStartLF = LeftFrontWheel.currentPosition();
  pivotStartLB = LeftBackWheel.currentPosition();
  pivotStartRF = RightFrontWheel.currentPosition();
  pivotStartRB = RightBackWheel.currentPosition();
  if (mode == PIVOT_RIGHT) {
    setAllMotorSpeeds((int)PIVOT_SPEED, -(int)PIVOT_SPEED);
    Serial.println(F("Action: beginPivot(RIGHT)"));
  } else if (mode == PIVOT_LEFT) {
    setAllMotorSpeeds(-(int)PIVOT_SPEED, (int)PIVOT_SPEED);
    Serial.println(F("Action: beginPivot(LEFT)"));
uint32_t getPivotProgressSteps() {
  uint32_t lf = abs32(LeftFrontWheel.currentPosition() - pivotStartLF);
  uint32_t lb = abs32(LeftBackWheel.currentPosition() - pivotStartLB);
  uint32_t rf = abs32(RightFrontWheel.currentPosition() - pivotStartRF);
  uint32_t rb = abs32(RightBackWheel.currentPosition() - pivotStartRB);
  return (lf + lb + rf + rb) / 4;
void updatePivotLoop() {
  if (pivotMode == PIVOT_NONE) return;
  LeftFrontWheel.runSpeed();
  LeftBackWheel.runSpeed();
  RightFrontWheel.runSpeed();
  RightBackWheel.runSpeed();
  pivotStepsTaken = getPivotProgressSteps();
  if (pivotStepsTaken >= pivotStepsDesired) {
    finishPivot();
    Serial.print(F("Pivot complete, steps="));
    Serial.println(pivotStepsTaken);
// Navigation math
void computeDesiredBearing() {
  if (bearingAlignment == 0) return;
  uint32_t pathDistanceRemaining = 1;
  if (trackDir == 0) {
    if (pathTotalDistance > totalStepsTaken) {
      pathDistanceRemaining = pathTotalDistance - totalStepsTaken;
  } else {
    uint32_t remainingSteps = (combinedStepsDesired > totalStepsTaken) ? (combinedStepsDesired - totalStepsTaken) : 0;
    if (pathTotalDistance > remainingSteps) {
      pathDistanceRemaining = pathTotalDistance - remainingSteps;
  if (pathDistanceRemaining == 0) pathDistanceRemaining = 1;
  bool reflectorIsLeft = (desiredBearing100 >= 9100);
  int32_t signedOppositeDistance = (int32_t)oppositeDistance;
  if (reflectorIsLeft) {
    signedOppositeDistance = -labs(signedOppositeDistance);
  } else {
    signedOppositeDistance = labs(signedOppositeDistance);
  float angleDeg = atan2((float)signedOppositeDistance, (float)pathDistanceRemaining) * 180.0f / PI;
  int32_t bearing100 = (int32_t)((90.0f + angleDeg) * 100.0f);
  if (bearing100 < 0) bearing100 = 0;
  if (bearing100 > 18000) bearing100 = 18000;
  desiredBearing100 = (uint16_t)bearing100;
  if (abs((int)desiredBearing100 - (int)lastSentDesiredBearing100) >= 100) {
    sendDesiredBearing(desiredBearing100);
void updateBearingDiff() {
  bearingDiffTarget = (int16_t)actualBearing100 - (int16_t)desiredBearing100;
  if (bearingDiffTarget > -BEARING_DEADBAND && bearingDiffTarget < BEARING_DEADBAND) {
  if (bearingDiffRamped < bearingDiffTarget) {
    bearingDiffRamped += BEARING_UPDATE_SMOOTH;
    if (bearingDiffRamped > bearingDiffTarget) bearingDiffRamped = bearingDiffTarget;
  } else if (bearingDiffRamped > bearingDiffTarget) {
    bearingDiffRamped -= BEARING_UPDATE_SMOOTH;
    if (bearingDiffRamped < bearingDiffTarget) bearingDiffRamped = bearingDiffTarget;
void applyForwardMotion() {
  int16_t diff = bearingDiffRamped;
  int16_t absDiff = abs(diff);
  if (absDiff < BEARING_DEADBAND) {
    absDiff = 0;
  // smoother startup ramp
  if (rampedSpeed < normalSpeed) {
    if (rampedSpeed == 0) {
      rampedSpeed = MIN_FORWARD_SPEED;
    } else {
      rampedSpeed += SPEED_RAMP_STEP;
    if (rampedSpeed > normalSpeed) {
      rampedSpeed = normalSpeed;
  } else if (rampedSpeed > normalSpeed) {
    rampedSpeed -= SPEED_DECAY_STEP;
    if (rampedSpeed < normalSpeed) rampedSpeed = normalSpeed;
  // reduce aggressive steering effect
  int32_t steerAdjust = absDiff * 1;
  if (steerAdjust > MAX_BEARING_SPEED_ADJUST) {
    steerAdjust = MAX_BEARING_SPEED_ADJUST;
  int leftSpeed = rampedSpeed;
  int rightSpeed = rampedSpeed;
  if (diff > 0) {
    leftSpeed = (int)rampedSpeed - (int)steerAdjust;
    rightSpeed = (int)rampedSpeed + (int)steerAdjust;
  } else if (diff < 0) {
    leftSpeed = (int)rampedSpeed + (int)steerAdjust;
    rightSpeed = (int)rampedSpeed - (int)steerAdjust;
  leftSpeed = constrain(leftSpeed, 0, (int)normalSpeed);
  rightSpeed = constrain(rightSpeed, 0, (int)normalSpeed);
  setAllMotorSpeeds(leftSpeed, rightSpeed);
  Serial.print(F("FORWARD rampedSpeed="));
  Serial.print(rampedSpeed);
  Serial.print(F(" diff="));
  Serial.print(diff);
  Serial.print(F(" left="));
  Serial.print(leftSpeed);
  Serial.print(F(" right="));
  Serial.println(rightSpeed);
void updateObstacleScanSchedule() {
  if (totalStepsTaken >= nextScanStep) {
    sendObstacleScanRequest();
    nextScanStep += scanIntervalSteps;
void runForwardLoop() {
  if (!navRunning) return;
  computeDesiredBearing();
  updateBearingDiff();
  applyForwardMotion();
  totalStepsTaken = getAverageAbsStepperPosition();
  updateObstacleScanSchedule();
  if (combinedStepsDesired > 0 && totalStepsTaken >= combinedStepsDesired) {
    stopMotors();
    sendTotalSteps(totalStepsTaken);
    resetNavigationState();
// Packet handlers
void handleWaypointPacket(const uint8_t* data, uint8_t len) {
  if (len != 22) {
    Serial.print(F("Waypoint length error: "));
    Serial.println(len);
    return;
  pathTotalDistance = readUInt32LE(&data[0]);
  combinedStepsDesired = readUInt32LE(&data[4]);
  oppositeDistance = (int32_t)readUInt32LE(&data[8]);
  bearingAlignment = data[12];
  desiredBearing100 = readUInt16LE(&data[13]);
  actualBearing100 = readUInt16LE(&data[15]);
  trackDir = data[17] & 0x01;
  scanIntervalSteps = readUInt32LE(&data[18]);
  Serial.println(F("RX: WAYPOINT DATA"));
  Serial.print(F(" pathTotalDistance=")); Serial.println(pathTotalDistance);
  Serial.print(F(" combinedStepsDesired=")); Serial.println(combinedStepsDesired);
  Serial.print(F(" oppositeDistance=")); Serial.println(oppositeDistance);
  Serial.print(F(" bearingAlignment=")); Serial.println(bearingAlignment);
  Serial.print(F(" desiredBearing100=")); Serial.println(desiredBearing100);
  Serial.print(F(" actualBearing100=")); Serial.println(actualBearing100);
  Serial.print(F(" trackDir=")); Serial.println(trackDir);
  Serial.print(F(" scanIntervalSteps=")); Serial.println(scanIntervalSteps);
  sendCmdOnly(RSP_NAV_ACK);
  beginForwardNavigation();
void handlePacket(uint8_t cmd, const uint8_t* data, uint8_t len) {
  switch (cmd) {
    case CMD_STOP_MOTORS:
      stopMotors();
      break;
    case CMD_ACTUAL_BEARING:
      if (len == 2) {
        actualBearing100 = readUInt16LE(data);
        Serial.print(F("RX: ACTUAL BEARING x100 = "));
      break;
    case CMD_RIGHT_PIVOT:
      if (len == 2 && !navRunning) {
        uint16_t steps = readUInt16LE(data);
        Serial.print(F("RX: RIGHT PIVOT steps="));
        beginPivot(PIVOT_RIGHT, steps);
      break;
    case CMD_LEFT_PIVOT:
        Serial.print(F("RX: LEFT PIVOT steps="));
        beginPivot(PIVOT_LEFT, steps);
      break;
    case CMD_WAYPOINT_DATA:
      if (!navRunning) {
        handleWaypointPacket(data, len);
      break;
// UART parser
void processIncomingByte(uint8_t b) {
  switch (parserState) {
    case WAIT_HEADER:
      if (b == UART_HEADER) parserState = WAIT_CMD;
      break;
    case WAIT_CMD:
      currentCmd = b;
      runningChecksum = b;
      parserState = WAIT_LEN;
      break;
    case WAIT_LEN:
      expectedLen = b;
      runningChecksum ^= b;
      if (expectedLen > MAX_PAYLOAD) {
      } else if (expectedLen == 0) {
        parserState = WAIT_CHECKSUM;
      } else {
        payloadIndex = 0;
        parserState = WAIT_PAYLOAD;
      break;
    case WAIT_PAYLOAD:
      payload[payloadIndex++] = b;
      if (payloadIndex >= expectedLen) {
      break;
    case WAIT_CHECKSUM:
      if (b == runningChecksum) {
        handlePacket(currentCmd, payload, expectedLen);
      } else {
        Serial.println(F("Checksum error"));
      currentCmd = 0;
      expectedLen = 0;
      payloadIndex = 0;
      break;
void readIncomingUart() {
    processIncomingByte((uint8_t)Serial3.read());
// Arduino entry points
void setup() {
  delay(1000); // give USB/serial time to settle
  Serial.begin(115200);
  Serial3.begin(115200);
  LeftFrontWheel.setMaxSpeed(2000);
  LeftBackWheel.setMaxSpeed(2000);
  RightFrontWheel.setMaxSpeed(2000);
  RightBackWheel.setMaxSpeed(2000);
  LeftFrontWheel.setAcceleration(800);
  LeftBackWheel.setAcceleration(800);
  RightFrontWheel.setAcceleration(800);
  RightBackWheel.setAcceleration(800);
  multiStepper.addStepper(LeftFrontWheel);
  multiStepper.addStepper(LeftBackWheel);
  multiStepper.addStepper(RightFrontWheel);
  multiStepper.addStepper(RightBackWheel);
  resetPivotState();
  Serial.println(F("ARDUINO_v10 ready"));
void loop() {
  readIncomingUart();
  if (navRunning) {
    runForwardLoop();
  } else {
    updatePivotLoop();
USB
Digital 21
Absolutely - here’s a cleaner applyForwardMotion() that uses:
  • a deadband to ignore tiny bearing errors
  • a tunable proportional gain
  • a maximum steering cap
  • your symmetric steering behavior
Suggested constants
Add these near your steering constants:
static const int16_t BEARING_DEADBAND = 3;      // x100 units, so 3 = 0.03 degrees
static const int16_t STEERING_GAIN = 12;        // higher = stronger steering response
Rewritten applyForwardMotion()
  // If we're holding steering during obstacle scan, keep motor speeds centered
  if (scanHoldSteering) {
    int32_t baseSpeed = rampedSpeed;
    if (baseSpeed > 2000) baseSpeed = 2000;
    if (baseSpeed < MIN_FORWARD_SPEED) baseSpeed = MIN_FORWARD_SPEED;
    setAllMotorSpeeds((int)baseSpeed, (int)baseSpeed);
    return;
  // Difference is in x100 degrees
  int32_t diff = (int32_t)actualBearing100 - (int32_t)desiredBearing100;
  // Ignore tiny errors
  if (labs(diff) <= BEARING_DEADBAND) {
    diff = 0;
  if (baseSpeed < MIN_FORWARD_SPEED) {
  // Proportional steering:
  // steerAdjust grows as error grows
  int32_t steerAdjust = labs(diff) / STEERING_GAIN;
  // Clamp correction
  int32_t leftSpeed = baseSpeed;
  int32_t rightSpeed = baseSpeed;
  // Symmetric steering
  // Change sign here if your steering direction is reversed
  if (diff > 0) {
    leftSpeed -= steerAdjust;
    rightSpeed += steerAdjust;
    leftSpeed += steerAdjust;
    rightSpeed -= steerAdjust;
  // Final clamp
  if (leftSpeed > 2000) leftSpeed = 2000;
  if (rightSpeed > 2000) rightSpeed = 2000;
  if (leftSpeed < -2000) leftSpeed = -2000;
  if (rightSpeed < -2000) rightSpeed = -2000;
  setAllMotorSpeeds((int)leftSpeed, (int)rightSpeed);
  Serial.print(F("NAV: base="));
  Serial.print(baseSpeed);
  Serial.print(diff);
  Serial.print(F(" steer="));
  Serial.print(steerAdjust);
  Serial.print(F(" L="));
  Serial.print(F(" R="));
How to tune it
STEERING_GAIN
This controls how quickly steering responds to error.
  • smaller number = stronger steering
  • larger number = weaker steering
Examples:
  • 8 = aggressive
  • 12 = moderate
  • 20 = gentle
BEARING_DEADBAND
This prevents the robot from constantly correcting tiny bearing noise.
Since your bearing is in x100 units:
  • 3 = 0.03
  • 50 = 0.5
  • 100 = 1.0
For real robots, you may want something more like 50 to 150 depending on sensor noise.
Important note
If your steering still turns the wrong way, just swap the signs here:
if (diff > 0) {
to the opposite polarity.
If you want, I can also give you a full Arduino_v11c with this new steering function already integrated into the complete sketch.
Thank you @Athena for the update. Can you please give me a full Arduino_v11c with this new steering function already integrated into the complete sketch? Thanks. Jack
Absolutely - below is a full Arduino_v11c with the new proportional steering integrated, plus:
  • deadband
  • tunable steering gain
  • max steering cap
  • symmetrical left/right PWM correction
  • scan hold steering so the robot does not keep correcting hard during an Obs Scan Request
I also kept the same packet/protocol structure you were using.
// Arduino_v11c
#include <Arduino.h>
// Protocol
// Arduino -> ARC
// Motor setup
// Parser
enum ParserState
  WAIT_HEADER,
  WAIT_CMD,
  WAIT_LEN,
  WAIT_PAYLOAD,
  WAIT_CHECKSUM
// Navigation state
bool scanHoldSteering = false;
// Steering tuning
static const int16_t BEARING_DEADBAND = 3;          // x100 units, 3 = 0.03 degrees
// Optional smoothing on bearing diff
// Steering polarity
// If the robot steers the wrong direction, change this from 1 to -1.
static const int8_t STEERING_POLARITY = 1;
// Pivot state
enum PivotMode
  PIVOT_NONE,
  PIVOT_RIGHT,
  PIVOT_LEFT
// Helpers
  Serial3.write(cmd);
  Serial3.write(len);
  uint8_t tmp[4];
  uint8_t tmp[2];
  // Neutralize steering before scan request
  scanHoldSteering = true;
    Serial3.read();
  pivotStartLF = 0;
  pivotStartLB = 0;
  pivotStartRF = 0;
  pivotStartRB = 0;
void stopMotors()
void finishPivot()
  stopMotors();
  resetPivotState();
  currentSpeed = 0;
  rampedSpeed = 0;
  navRunning = false;
  navRunning = true;
  currentSpeed = 0;
  rampedSpeed = 0;
  if (steps == 0)
    return;
  pivotMode = mode;
    finishPivot();
// Navigation math
  if (trackDir == 0)
  else
      : 0;
  else
    return;
    return;
  int32_t steerAdjust = (labs(diff) * STEERING_GAIN) / 100;
  // If polarity is wrong, flip STEERING_POLARITY between 1 and -1.
  if (diff > 0)
    leftSpeed -= (steerAdjust * STEERING_POLARITY);
    rightSpeed += (steerAdjust * STEERING_POLARITY);
  else if (diff < 0)
    leftSpeed += (steerAdjust * STEERING_POLARITY);
    rightSpeed -= (steerAdjust * STEERING_POLARITY);
  Serial.print(diff);
  if (scanIntervalSteps == 0) return;
    stopMotors();
// Packet handlers
  if (len != 22)
    return;
  switch (cmd)
      stopMotors();
      break;
      if (len == 2)
        scanHoldSteering = false;   // resume steering once fresh bearing is received
      break;
      break;
      break;
      if (!navRunning)
      break;
    default:
      break;
// UART parser
    case WAIT_HEADER:
      break;
    case WAIT_CMD:
      currentCmd = b;
      break;
    case WAIT_LEN:
      expectedLen = b;
      else
        payloadIndex = 0;
      break;
    case WAIT_PAYLOAD:
      break;
    case WAIT_CHECKSUM:
      else
      currentCmd = 0;
      expectedLen = 0;
      payloadIndex = 0;
      break;
void setup()
  delay(1000);
  resetPivotState();
  Serial.println(F("ARDUINO_v11c ready"));
void loop()
  readIncomingUart();
  if (navRunning)
    runForwardLoop();
  else
    updatePivotLoop();
What changed in v11c
1) Proportional steering
This line makes steering scale more cleanly:
So:
  • bigger bearing error = stronger correction
  • smaller bearing error = gentler correction
  • STEERING_GAIN controls the strength
2) Deadband
Tiny errors are ignored:
3) Scan hold steering
When the Arduino sends the obstacle scan request:
And when ARC sends a fresh bearing:
That prevents the robot from carrying over a stale steering correction during the scan.
Tuning tips
If steering feels too weak:
  • increase STEERING_GAIN to 15, 20, or 25
If steering is too aggressive:
  • reduce STEERING_GAIN
  • reduce MAX_BEARING_SPEED_ADJUST
If it chatters near center:
  • increase BEARING_DEADBAND
If the robot turns the wrong way:
  • flip this:
static const int8_t STEERING_POLARITY = -1;
to:
One important note
Your original snippet had a few corrupted fragments from copy/paste, so if you want, I can do one more pass and give you a fully compile-checked cleaned version with:
  • consistent function names
  • no duplicated logic
  • easier tuning constants
  • comments trimmed for readability
If you'd like, I can also write the matching ARC JavaScript that sends actualBearing100, waypoint, and Obs Scan Request packets cleanly.
Thank you @Athena for the update. However, normalSpeed (600) is never reached. The motors are stuck at MIN_FORWARD_SPEED (60).
Can you please rewrite the Arduino_v11c to correct the motor speed stuck at the lower limit? Can you please rewrite it as a fully compile-checked cleaned version? Please include:
Thanks. Jack
Sorry, I can't continue helping in this thread. It's grown long enough that my context window will require too much extra processing, which makes follow-ups unreliable and I can start making mistakes.
A couple of options:
  • Start a new thread that picks up where we left off - fresh context, faster responses.
  • Or get unlimited interaction with me through ARC's built-in AI Assistant agent: Synthiam AI Assistant
Thank you @Athena for great help. Jack
