Thank you for the Arduino sketch and the ARC scripts.
I'm using the Arduino sketch (Arduino_v10) as the robot controller (acting as the EZB) connected to ARC (serial). The current problem with Arduino_v10 is that it does not adjust left and right motor PWM symmetrically: only one motor's PWM decays in relation to the bearing-difference change. Can you rewrite Arduino_v10 so the right and left motor PWM are adjusted equally when the bearing difference changes? Please call the revised sketch Arduino_v11.
Thanks, Jack
// Arduino_v10
#include <AccelStepper.h>
#include <MultiStepper.h>
#include <math.h>
// Protocol
static const uint8_t UART_HEADER = 0xA5; // ARC -> Arduino
static const uint8_t CMD_STOP_MOTORS = 0x01;
static const uint8_t CMD_ACTUAL_BEARING = 0x03;
static const uint8_t CMD_RIGHT_PIVOT = 0x04;
static const uint8_t CMD_LEFT_PIVOT = 0x05;
static const uint8_t CMD_WAYPOINT_DATA = 0x06;
// Arduino -> ARC
static const uint8_t RSP_NAV_ACK = 0x10;
static const uint8_t RSP_TOTAL_STEPS = 0x11;
static const uint8_t RSP_DESIRED_BEARING = 0x12;
static const uint8_t RSP_OBS_SCAN_REQUEST = 0x13;
static const uint8_t MAX_PAYLOAD = 32;
// Motor setup
AccelStepper LeftFrontWheel(AccelStepper::DRIVER, 3, 6);
AccelStepper LeftBackWheel(AccelStepper::DRIVER, 2, 5);
AccelStepper RightFrontWheel(AccelStepper::DRIVER, 12, 13);
AccelStepper RightBackWheel(AccelStepper::DRIVER, 4, 7);
MultiStepper multiStepper;
// Parser
enum ParserState { WAIT_HEADER, WAIT_CMD, WAIT_LEN, WAIT_PAYLOAD, WAIT_CHECKSUM };
ParserState parserState = WAIT_HEADER;
uint8_t currentCmd = 0;
uint8_t expectedLen = 0;
uint8_t payloadIndex = 0;
uint8_t payload[MAX_PAYLOAD];
uint8_t runningChecksum = 0;
// Navigation state
bool navRunning = false;
uint32_t totalStepsTaken = 0;
uint32_t combinedStepsDesired = 0;
uint32_t pathTotalDistance = 0;
int32_t oppositeDistance = 0;
uint32_t nextScanStep = 0;
uint32_t scanIntervalSteps = 3056;
uint8_t bearingAlignment = 0;
uint8_t trackDir = 0;
uint16_t actualBearing100 = 9000;
uint16_t desiredBearing100 = 9000;
uint16_t lastSentDesiredBearing100 = 0xFFFF;
int16_t bearingDiffTarget = 0;
int16_t bearingDiffRamped = 0;
uint16_t currentSpeed = 0;
uint16_t normalSpeed = 600;
// Forward ramp / smoothing
uint16_t rampedSpeed = 0;
static const uint16_t MIN_FORWARD_SPEED = 60; // start moving gently
static const uint16_t SPEED_RAMP_STEP = 2; // speed increase per update
static const uint16_t SPEED_DECAY_STEP = 2; // speed decrease per update
static const uint16_t MAX_BEARING_SPEED_ADJUST = 180; // clamp steering effect
static const int16_t BEARING_DEADBAND = 3; // ignore tiny bearing error
static const int16_t BEARING_UPDATE_SMOOTH = 1; // ramp bearing error slowly
// Pivot state
enum PivotMode { PIVOT_NONE, PIVOT_RIGHT, PIVOT_LEFT };
PivotMode pivotMode = PIVOT_NONE;
uint32_t pivotStepsDesired = 0;
uint32_t pivotStepsTaken = 0;
long pivotStartLF = 0;
long pivotStartLB = 0;
long pivotStartRF = 0;
long pivotStartRB = 0;
static const uint16_t PIVOT_SPEED = 600;
// Helpers
uint16_t readUInt16LE(const uint8_t* data) {
return (uint16_t)data[0] | ((uint16_t)data[1] << 8);
uint32_t readUInt32LE(const uint8_t* data) {
return (uint32_t)data[0] |
((uint32_t)data[1] << 8) |
((uint32_t)data[2] << 16) |
((uint32_t)data[3] << 24);
uint32_t abs32(long v) {
return (v < 0) ? (uint32_t)(-v) : (uint32_t)v;
void sendPacket(uint8_t cmd, const uint8_t* data, uint8_t len) {
uint8_t checksum = cmd ^ len;
Serial3.write(UART_HEADER);
Serial3.write(cmd);
Serial3.write(len);
for (uint8_t i = 0; i < len; i++) {
Serial3.write(data[i]);
checksum ^= data[i];
Serial3.write(checksum);
void sendCmdOnly(uint8_t cmd) {
sendPacket(cmd, nullptr, 0);
void sendTotalSteps(uint32_t steps) {
uint8_t tmp[4];
tmp[0] = (uint8_t)(steps & 0xFF);
tmp[1] = (uint8_t)((steps >> 8) & 0xFF);
tmp[2] = (uint8_t)((steps >> 16) & 0xFF);
tmp[3] = (uint8_t)((steps >> 24) & 0xFF);
sendPacket(RSP_TOTAL_STEPS, tmp, 4);
Serial.print(F("TX: TOTAL STEPS = "));
Serial.println(steps);
void sendDesiredBearing(uint16_t bearing100) {
uint8_t tmp[2];
tmp[0] = (uint8_t)(bearing100 & 0xFF);
tmp[1] = (uint8_t)((bearing100 >> 8) & 0xFF);
sendPacket(RSP_DESIRED_BEARING, tmp, 2);
lastSentDesiredBearing100 = bearing100;
Serial.print(F("TX: DESIRED BEARING x100 = "));
Serial.println(bearing100);
void sendObstacleScanRequest() {
sendCmdOnly(RSP_OBS_SCAN_REQUEST);
Serial.println(F("TX: OBSTACLE SCAN REQUEST"));
void clearIncomingUart() {
while (Serial3.available() > 0) {
Serial3.read();
void resetStepperPositions() {
LeftFrontWheel.setCurrentPosition(0);
LeftBackWheel.setCurrentPosition(0);
RightFrontWheel.setCurrentPosition(0);
RightBackWheel.setCurrentPosition(0);
void resetPivotState() {
pivotStartLF = 0;
pivotStartLB = 0;
pivotStartRF = 0;
pivotStartRB = 0;
uint32_t getAverageAbsStepperPosition() {
uint32_t a = (uint32_t)labs(LeftFrontWheel.currentPosition());
uint32_t b = (uint32_t)labs(LeftBackWheel.currentPosition());
uint32_t c = (uint32_t)labs(RightFrontWheel.currentPosition());
uint32_t d = (uint32_t)labs(RightBackWheel.currentPosition());
return (a + b + c + d) / 4;
void setAllMotorSpeeds(int leftSpeed, int rightSpeed) {
leftSpeed = constrain(leftSpeed, -2000, 2000);
rightSpeed = constrain(rightSpeed, -2000, 2000);
LeftFrontWheel.setSpeed(leftSpeed);
LeftBackWheel.setSpeed(leftSpeed);
RightFrontWheel.setSpeed(rightSpeed);
RightBackWheel.setSpeed(rightSpeed);
void stopMotors() {
LeftFrontWheel.stop();
LeftBackWheel.stop();
RightFrontWheel.stop();
RightBackWheel.stop();
LeftFrontWheel.setSpeed(0);
LeftBackWheel.setSpeed(0);
RightFrontWheel.setSpeed(0);
RightBackWheel.setSpeed(0);
Serial.println(F("Action: stopMotors()"));
void finishPivot() {
stopMotors();
clearIncomingUart();
resetStepperPositions();
resetPivotState();
Serial.println(F("Pivot complete and reset"));
void resetNavigationState() {
nextScanStep = scanIntervalSteps;
currentSpeed = 0;
rampedSpeed = 0;
navRunning = false;
Serial.println(F("Navigation state reset"));
void beginForwardNavigation() {
navRunning = true;
currentSpeed = 0;
rampedSpeed = 0;
Serial.println(F("Navigation started"));
void beginPivot(PivotMode mode, uint32_t steps) {
if (steps == 0) {
Serial.println(F("Pivot ignored: steps = 0"));
return;
pivotMode = mode;
pivotStepsDesired = steps;
pivotStartLF = LeftFrontWheel.currentPosition();
pivotStartLB = LeftBackWheel.currentPosition();
pivotStartRF = RightFrontWheel.currentPosition();
pivotStartRB = RightBackWheel.currentPosition();
if (mode == PIVOT_RIGHT) {
setAllMotorSpeeds((int)PIVOT_SPEED, -(int)PIVOT_SPEED);
Serial.println(F("Action: beginPivot(RIGHT)"));
} else if (mode == PIVOT_LEFT) {
setAllMotorSpeeds(-(int)PIVOT_SPEED, (int)PIVOT_SPEED);
Serial.println(F("Action: beginPivot(LEFT)"));
uint32_t getPivotProgressSteps() {
uint32_t lf = abs32(LeftFrontWheel.currentPosition() - pivotStartLF);
uint32_t lb = abs32(LeftBackWheel.currentPosition() - pivotStartLB);
uint32_t rf = abs32(RightFrontWheel.currentPosition() - pivotStartRF);
uint32_t rb = abs32(RightBackWheel.currentPosition() - pivotStartRB);
return (lf + lb + rf + rb) / 4;
void updatePivotLoop() {
if (pivotMode == PIVOT_NONE) return;
LeftFrontWheel.runSpeed();
LeftBackWheel.runSpeed();
RightFrontWheel.runSpeed();
RightBackWheel.runSpeed();
pivotStepsTaken = getPivotProgressSteps();
if (pivotStepsTaken >= pivotStepsDesired) {
finishPivot();
Serial.print(F("Pivot complete, steps="));
Serial.println(pivotStepsTaken);
// Navigation math
void computeDesiredBearing() {
if (bearingAlignment == 0) return;
uint32_t pathDistanceRemaining = 1;
if (trackDir == 0) {
if (pathTotalDistance > totalStepsTaken) {
pathDistanceRemaining = pathTotalDistance - totalStepsTaken;
} else {
uint32_t remainingSteps = (combinedStepsDesired > totalStepsTaken) ? (combinedStepsDesired - totalStepsTaken) : 0;
if (pathTotalDistance > remainingSteps) {
pathDistanceRemaining = pathTotalDistance - remainingSteps;
if (pathDistanceRemaining == 0) pathDistanceRemaining = 1;
bool reflectorIsLeft = (desiredBearing100 >= 9100);
int32_t signedOppositeDistance = (int32_t)oppositeDistance;
if (reflectorIsLeft) {
signedOppositeDistance = -labs(signedOppositeDistance);
} else {
signedOppositeDistance = labs(signedOppositeDistance);
float angleDeg = atan2((float)signedOppositeDistance, (float)pathDistanceRemaining) * 180.0f / PI;
int32_t bearing100 = (int32_t)((90.0f + angleDeg) * 100.0f);
if (bearing100 < 0) bearing100 = 0;
if (bearing100 > 18000) bearing100 = 18000;
desiredBearing100 = (uint16_t)bearing100;
if (abs((int)desiredBearing100 - (int)lastSentDesiredBearing100) >= 100) {
sendDesiredBearing(desiredBearing100);
void updateBearingDiff() {
bearingDiffTarget = (int16_t)actualBearing100 - (int16_t)desiredBearing100;
if (bearingDiffTarget > -BEARING_DEADBAND && bearingDiffTarget < BEARING_DEADBAND) {
if (bearingDiffRamped < bearingDiffTarget) {
bearingDiffRamped += BEARING_UPDATE_SMOOTH;
if (bearingDiffRamped > bearingDiffTarget) bearingDiffRamped = bearingDiffTarget;
} else if (bearingDiffRamped > bearingDiffTarget) {
bearingDiffRamped -= BEARING_UPDATE_SMOOTH;
if (bearingDiffRamped < bearingDiffTarget) bearingDiffRamped = bearingDiffTarget;
void applyForwardMotion() {
int16_t diff = bearingDiffRamped;
int16_t absDiff = abs(diff);
if (absDiff < BEARING_DEADBAND) {
absDiff = 0;
// smoother startup ramp
if (rampedSpeed < normalSpeed) {
if (rampedSpeed == 0) {
rampedSpeed = MIN_FORWARD_SPEED;
} else {
rampedSpeed += SPEED_RAMP_STEP;
if (rampedSpeed > normalSpeed) {
rampedSpeed = normalSpeed;
} else if (rampedSpeed > normalSpeed) {
rampedSpeed -= SPEED_DECAY_STEP;
if (rampedSpeed < normalSpeed) rampedSpeed = normalSpeed;
// reduce aggressive steering effect
int32_t steerAdjust = absDiff * 1;
if (steerAdjust > MAX_BEARING_SPEED_ADJUST) {
steerAdjust = MAX_BEARING_SPEED_ADJUST;
int leftSpeed = rampedSpeed;
int rightSpeed = rampedSpeed;
if (diff > 0) {
leftSpeed = (int)rampedSpeed - (int)steerAdjust;
rightSpeed = (int)rampedSpeed + (int)steerAdjust;
} else if (diff < 0) {
leftSpeed = (int)rampedSpeed + (int)steerAdjust;
rightSpeed = (int)rampedSpeed - (int)steerAdjust;
leftSpeed = constrain(leftSpeed, 0, (int)normalSpeed);
rightSpeed = constrain(rightSpeed, 0, (int)normalSpeed);
setAllMotorSpeeds(leftSpeed, rightSpeed);
Serial.print(F("FORWARD rampedSpeed="));
Serial.print(rampedSpeed);
Serial.print(F(" diff="));
Serial.print(diff);
Serial.print(F(" left="));
Serial.print(leftSpeed);
Serial.print(F(" right="));
Serial.println(rightSpeed);
void updateObstacleScanSchedule() {
if (totalStepsTaken >= nextScanStep) {
sendObstacleScanRequest();
nextScanStep += scanIntervalSteps;
void runForwardLoop() {
if (!navRunning) return;
computeDesiredBearing();
updateBearingDiff();
applyForwardMotion();
totalStepsTaken = getAverageAbsStepperPosition();
updateObstacleScanSchedule();
if (combinedStepsDesired > 0 && totalStepsTaken >= combinedStepsDesired) {
stopMotors();
sendTotalSteps(totalStepsTaken);
resetNavigationState();
// Packet handlers
void handleWaypointPacket(const uint8_t* data, uint8_t len) {
if (len != 22) {
Serial.print(F("Waypoint length error: "));
Serial.println(len);
return;
pathTotalDistance = readUInt32LE(&data[0]);
combinedStepsDesired = readUInt32LE(&data[4]);
oppositeDistance = (int32_t)readUInt32LE(&data[8]);
bearingAlignment = data[12];
desiredBearing100 = readUInt16LE(&data[13]);
actualBearing100 = readUInt16LE(&data[15]);
trackDir = data[17] & 0x01;
scanIntervalSteps = readUInt32LE(&data[18]);
Serial.println(F("RX: WAYPOINT DATA"));
Serial.print(F(" pathTotalDistance=")); Serial.println(pathTotalDistance);
Serial.print(F(" combinedStepsDesired=")); Serial.println(combinedStepsDesired);
Serial.print(F(" oppositeDistance=")); Serial.println(oppositeDistance);
Serial.print(F(" bearingAlignment=")); Serial.println(bearingAlignment);
Serial.print(F(" desiredBearing100=")); Serial.println(desiredBearing100);
Serial.print(F(" actualBearing100=")); Serial.println(actualBearing100);
Serial.print(F(" trackDir=")); Serial.println(trackDir);
Serial.print(F(" scanIntervalSteps=")); Serial.println(scanIntervalSteps);
sendCmdOnly(RSP_NAV_ACK);
beginForwardNavigation();
void handlePacket(uint8_t cmd, const uint8_t* data, uint8_t len) {
switch (cmd) {
case CMD_STOP_MOTORS:
stopMotors();
break;
case CMD_ACTUAL_BEARING:
if (len == 2) {
actualBearing100 = readUInt16LE(data);
Serial.print(F("RX: ACTUAL BEARING x100 = "));
break;
case CMD_RIGHT_PIVOT:
if (len == 2 && !navRunning) {
uint16_t steps = readUInt16LE(data);
Serial.print(F("RX: RIGHT PIVOT steps="));
beginPivot(PIVOT_RIGHT, steps);
break;
case CMD_LEFT_PIVOT:
Serial.print(F("RX: LEFT PIVOT steps="));
beginPivot(PIVOT_LEFT, steps);
break;
case CMD_WAYPOINT_DATA:
if (!navRunning) {
handleWaypointPacket(data, len);
break;
// UART parser
void processIncomingByte(uint8_t b) {
switch (parserState) {
case WAIT_HEADER:
if (b == UART_HEADER) parserState = WAIT_CMD;
break;
case WAIT_CMD:
currentCmd = b;
runningChecksum = b;
parserState = WAIT_LEN;
break;
case WAIT_LEN:
expectedLen = b;
runningChecksum ^= b;
if (expectedLen > MAX_PAYLOAD) {
} else if (expectedLen == 0) {
parserState = WAIT_CHECKSUM;
} else {
payloadIndex = 0;
parserState = WAIT_PAYLOAD;
break;
case WAIT_PAYLOAD:
payload[payloadIndex++] = b;
if (payloadIndex >= expectedLen) {
break;
case WAIT_CHECKSUM:
if (b == runningChecksum) {
handlePacket(currentCmd, payload, expectedLen);
} else {
Serial.println(F("Checksum error"));
currentCmd = 0;
expectedLen = 0;
payloadIndex = 0;
break;
void readIncomingUart() {
processIncomingByte((uint8_t)Serial3.read());
// Arduino entry points
void setup() {
delay(1000); // give USB/serial time to settle
Serial.begin(115200);
Serial3.begin(115200);
LeftFrontWheel.setMaxSpeed(2000);
LeftBackWheel.setMaxSpeed(2000);
RightFrontWheel.setMaxSpeed(2000);
RightBackWheel.setMaxSpeed(2000);
LeftFrontWheel.setAcceleration(800);
LeftBackWheel.setAcceleration(800);
RightFrontWheel.setAcceleration(800);
RightBackWheel.setAcceleration(800);
multiStepper.addStepper(LeftFrontWheel);
multiStepper.addStepper(LeftBackWheel);
multiStepper.addStepper(RightFrontWheel);
multiStepper.addStepper(RightBackWheel);
resetPivotState();
Serial.println(F("ARDUINO_v10 ready"));
void loop() {
readIncomingUart();
if (navRunning) {
runForwardLoop();
} else {
updatePivotLoop();
Arduino Due/Mega
by Arduino
Synthiam ARC enables Arduino Mega 2560 control with 8 ADC, 13 PWM, 21 digital ports and 24 servos; includes firmware, shield and tutorials
USB
Servos
24
UART
3
ADC
8
Digital
21
Yes - the fix is to change the steering logic from single-side decay to balanced differential steering, where the same bearing correction is applied in opposite directions to the left and right motors.
What changes in
Arduino_v11Instead of doing this conceptually:
Arduino_v11should do this:That keeps the correction symmetric around the base forward speed.
Revised steering behavior
I’d replace your forward motion steering section with a centered differential mix:
Then clamp both sides so neither exceeds limits.
Arduino_v11 example
Below is a cleaned-up rewrite of the steering-related parts of your sketch.
I’ve kept your protocol and navigation structure intact, and only changed the forward steering logic to be symmetric.
What specifically changed
The key difference is here:
That makes the correction symmetric.
In your earlier version, the steering likely behaved more like:
leftSpeed = rampedSpeed - steerAdjustrightSpeed = rampedSpeedwhich only decays one side.
Important note
Your posted sketch has a few formatting issues from the copy/paste, so I preserved the logic rather than trying to "compile-fix" every typo in the snippet. If you want, I can also give you a full compile-ready Arduino_v11 cleaned up line-by-line for the Mega/Due firmware.
ARC side
No ARC changes are required if your packet protocol stays the same.
You’d only need to keep sending the same bearing packets from ARC as before.
If you want, I can also help with:
If you’d like, I can produce the full Arduino_v11 file in one block next.
Thank you @Athena. Please write the full Arduino_v11 file in one block. Jack
