I have the Wio terminal:
https://www.hackster.io/SeeedStudio/display-robot-face-using-the-wio-terminal-68f87a
works great, but has no audio
This is the code I used for the Wio Terminal, how can it be used for a script in Synthiam with audio, emotions?
You are the programmer, my friend.
I can show a video of it on the Wio Terminal if you want to see it. Looks like the link above.
Here is the Arduino code:
#include
#include
Servo myservo;
//int outpin=D2;
int counter = 0;
int i = 0;
static LGFX lcd;
static LGFX_Sprite sprite(&lcd);
int pos = 0;
void drawEye(int x, int y) {
sprite.clear();
sprite.fillCircle(65,65,60,0xFFFF);
//sprite.drawEllipse(65,65,60,30,0xFFFF);
//sprite.drawFastHLine(5,62,120,0xFF);
sprite.fillCircle(x,y,15,0);
sprite.fillArc(65,65,60,1,180,360,0xED6E);
sprite.setPivot(65,65);
sprite.pushRotateZoom(80,70,0,1,0.5);
sprite.pushRotateZoom(240,70,0,1,0.5);
void sleepyEyes() {
int p_rect[4][4] = {{9,65,112,22},{22,65,86,41},{40,65,49,55},{63,65,4,59}};
sprite.clear();
sprite.fillCircle(65,70,10,0);
//sprite.fillArc(65,65,60,1,180,360,0xED6E);
for (int i=0;i<4;i++) {
sprite.fillArc(65,65,60,1,0,22*(i+1),0xED6E);
sprite.fillArc(65,65,60,1,180-(22*(i+1)),180,0xED6E);
sprite.fillRect(p_rect[i][0],p_rect[i][1],p_rect[i][2],p_rect[i][3],0xED6E);
delay(200);
delay(2000);
//sprite.pushRotateZoom(80,70,0,1,0.5);
//sprite.pushRotateZoom(240,70,0,1,0.5);
void setup() {
pinMode(WIO_5S_UP, INPUT_PULLUP);
pinMode(WIO_5S_DOWN, INPUT_PULLUP);
myservo.attach(0);
lcd.init();
lcd.setRotation(3);
lcd.setBrightness(128);
lcd.setColorDepth(16);
lcd.clear();
sprite.setColorDepth(16);
sprite.createSprite(130, 130);
drawEye(50,80);
lcd.drawArc(160,90,120,119,30,150,0xE800);
void loop() {
int x = random(15, 115);
for (pos = 0; pos <= 60; pos += 1) {
int l = pos + 20;
drawEye(l,80);
myservo.write(pos);
delay(80);
for (pos = 60; pos >= 0; pos -= 1) {
int l = pos;
drawEye(l,80);
myservo.write(pos);
delay(80);
delay(3000);
sleepyEyes();
You can have that Wio display accept UART commands from the USB cable and change expressions or something.
PS, your code is broken that you pasted because you did not wrap it in [ code ] or use the option. So it's missing characters. Specifically the #include lines at the top. You need to fix that
Anyway, you can have ARC send commands to the WIO using the Serial commands and have the WIO receive it. So on the WIO you'd modify the program to be something like.... (I can't test it so it probably won't work and needs you to do the rest).
Then in ARC you can init the COM port when you know what COMx the WIO is on. This javascript example...
Then, you can send commands to the COM port. Anything above 0 is an eye position. And 0 is sleepy eye position. Again, you need to know the COM port that the WIO is on that you initialized.
ok thanks - I mess around with it
I did copy the code from the link above. https://www.hackster.io/SeeedStudio/display-robot-face-using-the-wio-terminal-68f87a
It works on my Wio terminal just like the link above
check my kink out
still want to learn how the face can follow you, with audio, speech etc...
You are the programmer :-)
Always my best,
EzAng
