Speech Synthesis icon Speech Synthesis — Speak user-defined text via PC audio or EZ-B v4 speaker; configurable voices, effects and speed; uses Windows TTS; programmatically callable. Try it →
Spain
It is easy, T-connector cable to the battery, the motor cables without connectors, cable and servo to ez-b, of the latter can cut the red wire because it does not need the BEC
Spain
The link seems not to work for me, but I assume you mean these:
And the red wire of BEC can be eliminated:
yes those are the ones that i have thank you
OK, I need to ask... What kind of motors are you driving with 300 amps? You making a self driving car? A giant killer robot? The motor on my Toyota Prius is only 351 amps.
Nope it's 300A according to every web page and datasheet I can find on it.
Forward Current: 300A Reverse Current: 150A BEC: 2A Max 5.6V
That's one beast of a controller:)
Spain
I agree Rich, is a beast, but I doubt that the specification of 300 amps is real, do not think the cables or printed circuit hold much current, but if you hold 50 amps continuous to me and I think to most robots will simply so the best thing is the price. I use two engines and truth roomba I disconnected the fan by noise and do unnecessary power consumption
It might be a bit of over kill but better than too small. I am using it for a dagu 4wd chassis. Does anyone have manual of instruction sheet for this.
It is going to be the chassis for my Droid on Guard (dog)
