MPU9150 Accelerometer, Gyro, Temperature, Compass icon MPU9150 Accelerometer, Gyro, Temperature, Compass — MPU9150 ARC control reads compass, gyro, accelerometer and temperature via I2C, initializes and sets EZ-Script variables on demand. Try it →
India
I got the voltage regulators 1084-5.0 now. As this voltage regulator supplies the power only to the 5V and doesn't reach the microcontroller, is is okay if I use two of them in parallel to get 10A output on EZ-B to drive all the servos, this way I can avoid external power supply to the servos... Can the etching of the EZ-B take 10A?
dont know the answer to that but I think you will find the answer is no. Even if you find the boads tracing will handle it you also need to considder the header pins, connectors and wire suppling power to the motors.
No you cannot connect voltage regulators in parallel. The will not balance the workload. And that will cause unbalanced heat dissipation. The ideal suggesting is too have the vr handle half the servos, and the other vr handle the rest.
Thanks a lot @DJ for that valuable suggestion. I would go according to it... Can I know more about these unbalanced heat dissipation issues... Just for knowing the subject better...
