Resolved Resolved by Jeremie!
Questions With Brand New Ezb4
I have a problem with my brand new EZB4:
Basically what happens is:
  1. Connect the battery (charged)
  2. EZB starts blinking blue light
  3. No sound of connection/activation EZB
  4. Wifi connection with EZB in windows works
  5. Connecting in the EZB in the connection panel of the ARC does not work (see screenshot attached)
  6. If I do this procedure with my other EZB all works fine and a connection is made with ARC.
Attached to this thread you can see a screenshot of the code generated by ARC when trying to connect to the EZB. Here you can find also a video which I made to show what happens when I try to connect the EZB4 https://we.tl/3C4pRDRw8o
If anyone would have some advice or need more info on this problem? I will be happy to provide this. we.tl/3C4pRDRw8o
unfortunately no succes with these solutions, thanks ;-)
Hello @Buratino
Can you remove the EZ-B enclosure, power it up again, and look to see if there is a blue LED lit up on the bottom board?
This will indicate if the ARM chip is responding.
Jeremie is on it. Bowing out:) Edited to remove suggestions.
Hello Cochran Robotics and Jeremie, Thank you for looking at my EZB problem. Just removed the EZ-B enclosure, powered it up again, and noticed that there is no LED lighting up on the bottom board.
screenshot of the ARC while trying to connect..
It looks like there is a defect on the bottom board please contact customer support via the Contact Us page for warranty replacement.
