Resolved Resolved by Jeremie!
Questions With Brand New Ezb4
I have a problem with my brand new EZB4:
Basically what happens is:
  1. Connect the battery (charged)
  2. EZB starts blinking blue light
  3. No sound of connection/activation EZB
  4. Wifi connection with EZB in windows works
  5. Connecting in the EZB in the connection panel of the ARC does not work (see screenshot attached)
  6. If I do this procedure with my other EZB all works fine and a connection is made with ARC.
Attached to this thread you can see a screenshot of the code generated by ARC when trying to connect to the EZB. Here you can find also a video which I made to show what happens when I try to connect the EZB4 https://we.tl/3C4pRDRw8o
If anyone would have some advice or need more info on this problem? I will be happy to provide this. we.tl/3C4pRDRw8o
unfortunately no succes with these solutions, thanks ;-)
Hello @Buratino
Can you remove the EZ-B enclosure, power it up again, and look to see if there is a blue LED lit up on the bottom board?
This will indicate if the ARM chip is responding.
Jeremie is on it. Bowing out:) Edited to remove suggestions.
Hello Cochran Robotics and Jeremie, Thank you for looking at my EZB problem. Just removed the EZ-B enclosure, powered it up again, and noticed that there is no LED lighting up on the bottom board.
foto bottom board EZB
screenshot of the ARC while trying to connect..
It looks like there is a defect on the bottom board please contact customer support via the Contact Us page for warranty replacement.
