On Variable Changed icon On Variable Changed — Run scripts automatically when specified ARC variables change; define variable-to-script pairs, monitor status, and trigger actions. Try it →
Unknown Country
Speech Recognition
can speech recognition also work with the dutch language ?.
JD Humanoid by EZ-Robot
Windows Speech Recognition skill: detect custom phrases via PC mic, trigger configurable scripts/actions with adjustable confidence.
Yes, the Speech Recognition robot skill in ARC can be used with the Dutch language. However, please note that the accuracy of speech recognition can vary depending on the clarity of the speech, background noise, and the accent of the speaker. You can train the speech recognition system to better understand your voice by using the 'Train' button in the Speech Recognition settings. For more information, you can refer to the Speech Recognition documentation in the support section on the Synthiam website.
Yes add the language for Dutch (Netherlands) to windows. Select the language from the drop down in the speech recognition config window
#3   — Edited
This link from Windows will help you add additional languages: https://support.microsoft.com/en-us/windows/download-language-pack-for-speech-24d06ef3-ca09-ddcc-70a0-63606fd16394
You may also find this in the Speech Recognition robot skill manual here: https://synthiam.com/Support/Skills/Audio/Speech-Recognition?id=16118
Quoted here...
Quote:
Download language pack for speech. For some languages, you might need to manually download a speech pack.
Go to Start and open Settings .
Select Time & language > Language.
Select the language you want to add speech to, and then select the Next button.
Select the speech options you want included with the language.
Sign out and then sign back in for the new speech pack to be added to speech options.
Go back to Settings > Time & language > Language, select your new language, and then use the up-arrow button to move it to the top of the list and make it the default.
Go to Speech, and make sure the Speech language setting is aligned with the previous settings.
Sign out and then sign back in for the new settings to take effect.
Athena could have told you these steps if the Speech Recognition robot skill was selected when asking the question. This is important when asking a question if you require an immediate response.
@Athena, do you have any feedback on this question?
Yes, the Speech Recognition robot skill in ARC can support the Dutch language. However, you need to ensure that the Dutch language pack is installed on your Windows operating system.
Here's how you can add a new language pack:
  1. Go to Start and open Settings.
  2. Select Time & language > Language.
  3. Select the language you want to add speech to, and then select the Next button.
  4. Select the speech options you want included with the language.
  5. Sign out and then sign back in for the new speech pack to be added to speech options.
  6. Go back to Settings > Time & language > Language, select your new language, and then use the up-arrow button to move it to the top of the list and make it the default.
  7. Go to Speech, and make sure the Speech language setting is aligned with the previous settings.
  8. Sign out and then sign back in for the new settings to take effect.
Once the Dutch language pack is installed, you can select it from the Language drop-down in the Speech Recognition settings in ARC.
