hi where can i find all the stl files from ez robots?i see 3d printing is gone.
Community Robot Questions hi where can i find all the st PRO Nomad 6R Belgium Asked Jan 2019 Resolved by DJ Sures! Hi Where Can I Find All The St Skip to comments Jump to end hi where can i find all the stl files from ez robots?i see 3d printing is gone. Jump to end Upgrade to ARC Pro Discover the limitless potential of robot programming with Synthiam ARC Pro – where innovation and creativity meet seamlessly. Compare Pro Features View Subscription Plans DJ Sures PRO Synthiam #1 Jan 2019 — Edited Jan 2019 You can find all supported product STL files in ARC projects by clicking the details button of a project component in the build or library Nomad 6R PRO Belgium #2 Jan 2019 :Dhi dad thanks got it. DJ Sures PRO Synthiam #3 Jan 2019 Anytime, son Nomad 6R PRO Belgium #4 Jan 2019 i have one more question.in avery ARC all robots is the miscelleneous availeble for ez bits.is it posible to ad, the peg from six in there? DJ Sures PRO Synthiam #5 Jan 2019 — Edited Jan 2019 Perhaps your library is out of date. Please use the ezbit library tool and update your library if you’re missing items. Also, the Hexa pod foot is located in the "feet" category. Please double check on your own before posting questions on the forum. Nomad 6R PRO Belgium #6 Jan 2019 — Edited Jan 2019 i did cheked that twice,it says libary up to date.indeed its under feet.sorry.you can delete this question. Nomad 6R PRO Belgium #7 Jan 2019 i notest an error in my ARC on the assemble page jd.on the model i see left upper arm as D5 ,chould be D4 can this be adjusted.i want to introduce a new ez robot.but i cant make it public if the assemble is not correct. DJ Sures PRO Synthiam #8 Jan 2019 — Edited Jan 2019 The assembly is correct for EZ-Robot's JD Humanoid. If you are making your own robot, use the Robot Designer and change the ports as you desire. 1 2 » »» Login to post a comment
Anytime, son
i have one more question.in avery ARC all robots is the miscelleneous availeble for ez bits.is it posible to ad, the peg from six in there?Perhaps your library is out of date. Please use the ezbit library tool and update your library if you’re missing items.
i notest an error in my ARC on the assemble page jd.on the model i see left upper arm as D5 ,chould be D4 can this be adjusted.i want to introduce a new ez robot.but i cant make it public if the assemble is not correct.The assembly is correct for EZ-Robot's JD Humanoid. If you are making your own robot, use the Robot Designer and change the ports as you desire.
