Russia
Resolved Resolved by Nink!
Can't Connect To Rover
Hello, I have a problem, I can't connect to the wifi network of the Rover, Windows says that it was not possible to connect to the network. I use the tp-link TL-WN822N wifi usb adapter. One person told me that my adapter is too new for this robot, could this be true? Please tell me how to solve the problem. (I'm not a geek or a master of such things myself, but I'd like to figure it out)
Roli Rover by EZ-Robot
Roli WiFi planetary rover kit, customizable with 13 ez-bit ports for add-ons, built to traverse varied surfaces. Sold by EZ-Robot
#2   — Edited
Hello,
I read your post :
Are you using the latest ARC program?
Always when I can't connect - then I remember I need to shut off my anti - virus - This ways fixes my problem.
If that don't do it, check your firewalls.
Connection issues:
I agree with PTP on where to check :  https://synthiam.com/Tutorials/Lesson/14
or https://synthiam.com/Support/troubleshooting/Connection-Troubleshooting
PS. When you said rover in your post,  I thought you were talking about a Ez robot rover.
I don't know about a Brookstone Rover, don't believe Synthiam supports this.
EzAng
I am using 2013 version firmware v16 and there is support for this robot(brookstone rover 1.0). But to control it with ARC I should connect to his wifi, but i cant.
#4   — Edited
and if i try to connect to it the console displays this:
EZB 0:
EZB 1:
EZB 2:
EZB 3:
EZB 4:
TCP Server stopped
TCP Server stopped
TCP Server stopped
TCP Server stopped
TCP Server stopped
Rover Error: System.Net.Sockets.SocketException (0x80004005): The attempt to establish a connection was unsuccessful, because the required response was not received from another computer in the required time, or the already established connection was terminated due to an incorrect response from the already connected computer 192.168.1.100:80
    System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port)
    EZ_B.BrookstoneRover.Connect()
Twitter
#5   — Edited
Can you connect to the rover from your phone using the original app? Just make sure there is no technical issues with robot.
Did you try using 2013.02.26 version https://www.dropbox.com/sh/gx74x30gpifn1yv/AACOjST10aV_VQSYRbD9XIiMa See this thread https://synthiam.com/Community/Questions/Connecting-Brookstone-Rover-To-Ez-builder-Questions-2101
The wifi you have appears to supports 802.11n, 802.11b, 802.11g and the Brookstone appears to supports b/g so there should be no reason why you can't connect. When you connected your PC direct to the brook-stone robots Wifi did it connect ok ? Did it issue an IP address to your PC (from the command line in windows try typing ipconfig /all and see if it issued and IP and if you are connected to it).Can you ping the robots IP ?
Sorry I don't own a brookstone I think DJ has one. Looks nice from the video.
#6   — Edited
yes, I can connect to it whith my ipad.
the problem is that i can not connect to robot's wifi
Twitter
#7   — Edited
OK, Bummer:  So not an EZ-Robot issue.  All I can suggest is you read the manual for your TP Link adapter and see if you can force it to use 802.11g or b or get another wifi adapter.
Good luck.
OK Zoomer: thank you, sorry for wasting your time. ps im 15yo
